Advice when your dealer has trouble installing 21p22?
DrAchoo
Jason
Premium Rapid Red RWD, St. Batt Mach E
I took my 2021 job 2 in for the update today and they spent the "whole day" without success. I have to pick it up because I can't leave it for them to try another day. When I bring it back, can I direct them somehow to give them a head start for next try?
I suspect they haven't done this a ton, but you never know...
I think you need to flog one of the techs so they know you're serious
newmme
Volt
Some folks buy the cables off Amazon and take to dealer.
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
There isn’t anything in a Job 2 that should be giving them trouble. What are they saying is the issue? If you could send me your VIN I’m curious what FDRS shows in the history.
That update package loads fine for most vehicles but some are stubborn and it won't take. Nobody knows why. Not much you can do except to let the dealer keep trying. It may be successful eventually or it might just keep wasting your time.
Just a roll of the dice unfortunately...
Logal727
C
It’s only available for cars built through September, what is the date of OPs car?
newmme
Volt
That's ridiculous.
Not as ridiculous as you may think. That is the only way some folks have been able to get the dealers to successfully install updates. Below is one example for your reading pleasure :p
The dealership used my TrendNet adapter and amazonbasics cables. They were apparently doing things wrong the first 3 attempts. (The reason it took so long was because every time they accumulated 5 bad attempts, the VIN would lock out for 5 days. This repeated 3 times with them and I kept bringing it back).
Finally, they figured it out with tech support guiding them.
21P22 is not the Stuck OTA 1.7.1 update. 21P22 applies to 2021 Job 1 cars, a few 2021 Job 2 cars, and is a software calibration update. People were buying cables for the TSB 22-150 fix for cars that could not update to OTA 1.7.1 and beyond.
Mike G
N. AL, USA
'23 Mach-E GT-PE, '22 F-150 Lightning
Thank you I was about to say the same thing...people are conflating CSP 21P22 with the "stuck APIM due to an OTA problem" that's addressed by FSA 22-2150. They are not the same thing.
It's the 22-2150 stuck APIM that requires the extra cabling, CSP 21P22 addresses primarily the PCM and stuff like the door modules and RFA, etc.
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
A follow up to the thread after OP sent me their VIN. The dealership made some PTS look ups but never actually connected with FDRS.
May 24 is just another single PTS look up.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Does it actually have the updates pending? I've seen another car with a mid july build date that never showed the updated charging curve updates.
