AliRafiee
- Ali
- Jan 20, 2023
- Seattle WA
- 2022 Mach E GT - Grabber Blue
- Software Eng.
I have it on my 22. Way too cumbersome.
Tried it twice in my 21. Not worth the effort. About three months ago I thought I’d give it another go just because. Then I asked myself “Why?”. So I didn’t.I’ve got a first edition. Never used the feature. I guess I should try sometime but… meh.
I found it to be terrifying and terrible. Maybe Ford would have fixed it had they not removed the feature and killed any chance of developers improving it.How many of you use the auto-parking feature
i haven’t tried it yet. Didn’t know if it was more gimmicky or practi
It only requires a car on one wide, not both.I found it to be terrifying and terrible. Maybe Ford would have fixed it had they not removed the feature and killed any chance of developers improving it.
Issues: it only works if there are cars parked on both sides of the spot you want to back into (or in front and behind what you want to parallel park into). Then you have to actually get it to find the spot, which is usually ok but doesn't always work. Then you have to actually figure out which way to press the damn rocker button (I've failed that one a few times). If you're in a busy parking lot, you've got to do all this while people are riding your ass, and it requires turning on your blinker to indicate where to look for a spot while you slowly drive around like a fool.
If you manage to get it to start auto-parking, it will either immediately accelerate straight into one of the cars it is supposed to park between until you freak out and cancel it - or it will successfully position your car between the other two cars and freak itself out at the success and cancel itself half way into the spot. Honestly, it wouldn't surprise me if the code logic for success and "we're gonna crash" got switched.
Pretty sure I was able to successfully start auto-park 8 times and successfully complete auto-park once.
Yeah, there's 2 definitions of "requires" - there's "requires like the manual says" and "requires for the system to actually see a spot as a target and not drive past it without registering"It only requires a car on one wide, not both.
^ THIS ^The feature was only installed through some point early in the 2022 model year. It works. More or less. It's simultaneously too slow and too fast. I found it easier to just park the car myself.
My 2022 GT (built in Feb 2022) has it. (I've tried it a few times but it basically never sees any space that I would have wanted it to park in, so I haven't tried it in years.)Like I said. It was removed after the first year. 2021 was the first year.
