Battery balancing service?
LF699
Lawrence
Lexus CT 200h, Mach-E GTPE, Rivian R1T
I just dropped off my 2021 GTPE with 27000 miles off for the charge cord recall. They recommended a battery balancing service as recommended maintenance. Can someone tell me what that is and do I need it?
Thanks
TheSteelRider
United States
'21 Premium RWD
Thanks
That sounds really fishy. I've never heard of such a service before. I really question whether that's even a real thing. The BMS in the car should already balance the cells, because that is required in Lithium batteries.
Hopefully, one of the more knowledgeable forum members will see this post and double-check this.
I Googled and all I can come up with is a Hybrid battery balance in FORscan. But, the MME is not a Hybrid ...
Thanks
Open your manual, or FordPass, and find that. You won't. It's like when they want to do a power flush of your transmission. Run, run, as fast as you can.
Thanks
They’re trying to take advantage of you. Just don’t let them change your blinker fluid.
Thanks
OK, that’s bullshit because the battery management system already does that. Cells are constantly being balanced while the car is parked. There isn’t even a balancing procedure they can do, totally bogus.
They must need some kind of service to charge you for since EVs don’t really need maintenance.
RKinWA
Seattle, WA
2022 Mach-E GTPE Space White, 2023 Lincoln Corsair Pristine White Metallic
Blinker fluid ? However, it is very important to replace the air in your tires every 10k miles, especially for EVs
LF699
LF699
Lawrence
I couldn't find information on it and I knew that you guys on the forum could help. I appreciate all of your fast replies! Thanks!
YunniorO
Jacob
Westminster, Colorado
2021 Mach-E Premium AWD (Job 1)
If you don’t mind me asking, how much were they trying to charge you for this?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
It’s a real thing. Are they going to charge you for it?
ack154
2023 Mach-E GT PE
I'd ask them who recommends that as maintenance. If Ford does, can they show you some documentation of it in the service manual or something?
breeves002
St. Louis, MO
2021 Mach-E GT PE
They said it would cost $150.00 for the battery balancing.
Ask them what they even do. Like exact steps. Such a joke to even offer something like this that they can't even do and the car does already.
Its like when places charge for TPMS relearn even though Fords since about the early 2010's re-learn the sensors automatically after 2 minutes of driving.
LF699
LF699
Lawrence
The service advisor that recommended it by phone wasn't there when I dropped off the car. The ones there couldn't explain to me what is was and didn't have a technician available at the time.
