BlueCruise safety problem
mrjlhayes
James
Gilroy, CA
Carbonite Gray Premium Extended Battery AWD Mach-E
The thing that gets me is that it should be easy enough to write into the code that in a state like California the maximum speed limit *anywhere* is 75 mph, yet I have had the system believe that I was in zones with speed limits as high as 85-90mph.
AtomicInternet
SC
Focus RS, Mach E Rally
This is an exciting feature when I'm in a 55 zone with cruise set to 60, then it sees 45 and slams on the brakes. I can't seem to find where to disable it though, maybe because I've Forscan'd the crap out of my settings. I went into Driver Assistance, Speed Assist but the only option I have is "Speed Warning" and it's already disabled. Am I just not seeing it?
I think it's under adaptive cruise control not speed assist.
AtomicInternet
SC
Am I blind or did I somehow kill it with my Forscan changes? Is it predictive speed assist, because that says it helps around curves and useful things.
Ford Mustang Mach-E BlueCruise safety problem PXL_20230829_222107250
hybrid2bev
2026 Rally
Yes. It’s combined. Both speed assist for curves and speed limit sign reading.
kodiakng
Oregon
2023 Cyber Orange 4X Mach-E
turn off Predictive Speed Assist and it won't adjust speed based on speed sign recognition. it will still display speed signs in the IPC but won't actually adjust speed.
bbhaag
Maverick XLT, Mustang Mach-E GT Performance
well, there we go: another miss by ford that we even have 1.0 still out in the wild. thanks for the correction. ?
But the OP has a 2023 GT so I think your original instructions are correct. All 2023 models shipped with BC 1.2 and Sync 4.xx right?
kodiakng
Oregon
correct - @generaltso just added that the older generation was being neglected.
ChehRob
Rob
Seattle WA
ret
Probably if the software has any doubts about changing speed it should alert you first. Slowing down, not generally a danger; speeding up, more caution needed.
RedStormREHS
Martin
So Cal
Toyota Camry Hybrid / Toyota Sienna
Health Inspector
Ford Mustang Mach-E BlueCruise safety problem 20230629_172142
I got a great laugh one day when I saw my '21 GT's "speed limit sign" change near downtown LA! If only I could... and grow a couple wings too! [One of the signs I passed had been tagged all over with graffiti, ha!]
