Bumper panel cover popped out
Thesmoothdome
2021 Star White Metallic Premium eRWD
I've had my MME for a month now and never noticed this panel outside of reading on the forum about someone having to have this replaced and it being $450 for a new one due to paint matching. I'm shocked that just touching it while cleaning it popped the panel open and more than shocked to find it's only held on by single piece of plastic that isn't even fixed to the point it's slotted through.
Ford Mustang Mach-E Bumper panel cover popped out IMG_2582 (002)
Just put it back... #FirstWorldProblems
Thesmoothdome
Thesmoothdome
Gee Rick. Guess I never thought of that. Now that we’re done with the sarcasm, being as loose as it is, I can see these getting lost on a regular basis. At $450 to replace, it’s a regular money sink.
Motomax
Max
VW GLI, 4Runner
Get a ziptie sticky mount and stick it to the cover then ziptie it to the wires. If it pops off it won’t get lost.
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
There should be two wires behind the panel. They can be used to open the frunk in case of a battery failure. I don't have my car yet, so cannot comment on the tightness of a normal one.
Personally, I'd throw some clear gorilla tape over this until you can get an answer from the dealer.
It shouldn't come out that easily. I have washed my car dozens of times and that cover never budged. I have opened it a few times and each time I had to press in a very particular place to get it to pivot out and away from the cavity.
I wonder if your cover is missing any of the retention tabs?
This is the first report of the panel just popping off that I recall. I think they generally stay on pretty well.
Now that you popped it back in place, is it staying put?
zvez
chris
ga
yeah, that's a good idea, like a tether. That's what I did with my nav unit on my motorcycle. It's bad to see a $450 nav unit skipping down the road as you ride.
Mirak
Kansas
The one time I took mine through a car wash, it popped that cover off. It was dangling from the bumper.
It definitely feels a little loose but I’ve never had another issue with it popping off. The whole thing is a stupid design that needs to be fixed for the next model. You shouldn’t need a “jump” to open the hood. This is the kinda stuff engineers do. Engineering departments always need to be carefully managed and monitored by normal people. This idea somehow slipped through. SMDH.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Been a few post this has happened to.
Mine came out once popped it back in and has been good since. There is a reason for grey it is a duct tape color match ;).
If it pops out again a zip tie safety chain is an awesome idea.
Yep. The think tank jumped the tracks and then got lost in the woods.
It would have been much better to install a lock cylinder in the liftgate and put the LVB in back.
Or, maybe behind the pony on the front fascia that will open the hood.
Either one would be preferable to those little jumper wires tucked in back there.
But wait.......
Ford Engineers said a dead/flat 12v batter can't happen in this car because it's so well designed and the car will use the HVB to charge the LVB whenever needed. AND.....we will get various warning messages via Ford Pass before the LVB gets low enough to become a problem.
We all know how well that plan worked out....... :rolleyes:
Oh yeah......and because the people at Ford thought PaaK would work and everyone would want to use it.....no reason to have an actual keyed lock because nobody is going to carry fobs any more.
We all know how well that plan worked out.....:rolleyes:
My son borrowed my car yesterday. Could you imagine if I had to go through the crap to program PaaK into his phone just so he could borrow my car or give him my phone? Luckily we still have a fob. That is so much easier. Dumb that the key blank in there doesn't unlock anything.
Sounds like a comedy of mis-steps in play here...
nrevezzo
Nick
Buckeye, AZ
2021 Mach-E Rapid Red SR RWD
Mine pops off when I go through the car wash. I'm thinking I'll put some silicone caulk around the edges and glue it in place. I'll let the dealership deal with it if it ever needs to be used. IMO it's a pretty dumb way to solve the frunk problem. Can you say HACK!
Thesmoothdome
Thesmoothdome
It's stayed on. The zip tie sticky mount idea was brilliant as a failsafe and it's installed, but so far I haven't needed it. I doubt it will since I now know what to expect from the cover. If they could hinge the charger port cover, you'd think that they'd hinge this as well. It's an incredibly cheap move on an otherwise brilliant car.
