"Frunk" popped open on highway
louibluey
FE "Louibluey" GB
So, we need another one of those steel cables with a loop, in the cabin, to pull a wayward frunk closed (with a tie off post once closed, maybe a second loop for the closed postion).
Or, a frunk lid eject button that severs the frunk (explosive bolts?) and launches it safely to side of the road, where it decends safely by its own parachute :)
GoGoGadgetMachE
"Bluey... Loui Bluey" ?da da, da daaaaaa?
santa fe,nm
www.envirokarma.org
Solar Sales/install
So today I was driving home and between my "fun" of trying to find a charger that worked, I was on the highway when the "frunk" popped open about an inch, got a warning telling me to pull over and close it.
Now, it could be that I didn't close it tightly the last time I used it (yesterday) but I did have about 200 miles driving at 70mph before this happened.
Hoping this was a "frunk" fluke, but it was rather unnerving.
yikes!
...good thing the secondary latch caught it.
I have noticed it is fairly difficult to shut the Frunk... you can't just drop it from a few inches up and expect it to engage all the way. It takes a firm push to catch the second latch, so firm in fact I am a little concerned with denting the hood.
Has anyone found a way to adjust so that it is easier to fully engage?
RyZt
San Jose
Mach E4X
yikes!
I was able to get the frunk shut fully when dropping it from height by asserting additional downward force as I drop it (like how you slam shut a door). I'm not successful every times though.
I'm concerned about denting the hood as well.
Regularmache
Stephen
US
Purchasing
Check your Fridge light! That little gnome that turns the light on and off may have wanted a Pony ride and jumped in the Frunk!
*serious note, myself, wife and kids had Frunk closing training and practice. All four fingers on the leading edge of Frunk, drop/push and follow through all the way down. Don't change your pressure and frunk closes securely. The Gasket creates a pressure once the hood engages it fully and the little one way drain valve, actually releases a little whoosh of air.
JCHLi
JCHLi
So the dealer looked at it and had to body shop adjust the stops so they weren't pushing up so hard. Seems to close easier now, we'll see if it ever happens again.
santa fe,nm
www.envirokarma.org
Solar Sales/install
do you happen to know WHICH stops?
There are two fat round ones on the sides, and two rectangular hard ones in the front...
I can't see any way to adjust the front ones, or the latch itself, without removing the whole Frunk to get to the mechanism
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
I've tried adjusting the round ones. They just turn to go up or down. All the way down it made little difference. It did seem like once it was half latches, I could push it down and make it fully latch easier. But the actual closing still only catches the first latch unless you slam it.
JCHLi
JCHLi
Round ones. Still you need to push down after closing, just not quite as hard. I guess these stops push back up on the hood, keep it all nice and tight so don't over adjust (in my opinion)
Tpaguy
Tampa
2021 Ford Mach E First Edition
I’ve now had my Mach E for about 500 miles and honestly the only irk I’ve found is the difficulty to close the trunk makes it where I don’t even want to use it. I just opened it and it took me five tries and about ten minutes to close it properly
I doubt anything can be done now about it, without changing out the latching mechanism. Alas, I’m just going to leave the frunk alone except for if absolutely necessary to open.
Luda07
Christopher
Colorado Springs
Mach E and Explorer Sport
Pilot
§ 571.113 Standard No. 113; Hood latch system.
S1. Purpose and scope. This standard establishes the requirement for providing a hood latch system or hood latch systems.
S2. Application. This standard applies to passenger cars, multipurpose passenger vehicles, trucks, and buses.
S3. Definitions. Hood means any exterior movable body panel forward of the windshield that is used to cover an engine, luggage, storage, or battery compartment.
S4. Requirements.
S4.1 Each hood must be provided with a hood latch system.
S4.2 A front opening hood which, in any open position, partially or completely obstructs a driver's forward view through the windshield must be provided with a second latch position on the hood latch system or with a second hood latch system.
Ah! So I don’t have to call it a frunk!
santa fe,nm
www.envirokarma.org
Solar Sales/install
I agree the frunk latch is a bit stiff, and no good way to adjust as far as I can tell. I have found that with a little practice there is a 'sweet-spot', not quite a slam, that seems to work pretty well.....
gentle drop to first click, and then 'CPR' push for second doesn't work very well with this latch.
