- TimCO
- Dec 30, 2019
- Colorado, USA
- 2021 Mustang Mach-E FE, 2023 Bronco Sport OB
- Retired
Ah, I think I see what you're asking. I didn't even know the charging schedule setting would show me the current map and address after clicking on Home. I just went and looked and the answer appears to be "sometimes".I have a barn and 4 other out buildings all with metal roofs but all at least 30 yards from the car. The house is wood framed brick veneer with shingle roof. As noted it know where the car is and nav works.
You misunderstood what I was asking I will try to be clearer. I am not concerned about what the address is when you pick (what comes up) when you set up the charging schedule. What I am asking is the one displayed in the car charging schedule, settings, charging, edit schedule the same address as the one on the phone, vehicle, manage vehicle, charging times? Do the addresses in sync (car) and fordpass (phone) for your charging location match?
First, let me say that I was mistaken above when I said it was picking up a false address for the side street. I didn't realize that the street on the corner is also a N-S street like mine (it curves around). It was actually picking up the valid address of house directly behind me on that street (just one digit off, and I didn't notice). When I went out now and looked, it was still showing my current location as the address for the house behind me.
So I deleted that charge location/schedule, did a 1-minute charge to populate a new charging address, and it still came up with the house behind me. So I went ahead and added a schedule to it, and named it Home (figuring I was stuck with that). But then after backing out and going back in to see my current location, this time it showed a new address, for the house across the street! The 3 houses are located basically in a triangle, each about 200' from the other.
I do remember the first time I did it when I got the car, it found my actual address though. Now it's only getting close. And is varying just enough to sometimes identify the address as any one of the 3 houses.
I guess that's no big deal as long as the "circle" it draws around the saved location is big enough to accept any of the 3 houses as being Home, and will charge according to the schedule. Time will tell whether it does that dependably or not. I've probably done 6 overnight charges now, and all but one worked.
