Car just died
agoldman
Charleston, SC
If that hard boot trick is real, this may be the greatest ME thread if all time!
mjschillingtec
MJ
Mach E GT Grabber Blue; BMW 328i Convertible
Business
I've been putting together a trouble shooting guide for 12V battery issues and car stopping/not starting problems. I've added in the "hold power button for 1 minute" idea as a possible trick to try to fix the problem. Would be nice if another forum member could replicate that solution to verify it works. Not that I'm hoping somebody's car stops working or anything..
good summary doc right there. I hope I don't regret not stopping right now to print this out and put it in my records
BadgerGreg
North Carolina
2023 Mach E Premium RWD SR and 2022 BMW i4 M50
My Mach E cal route 1 just died on the road while driving on the surface road at around 20 miles/hour. It refused to do anything for 15-20 minutes.
What type(s) of warning(s) did you get? Did you get the STOP SAFELY NOW message at any point during your situation? If you did, I strongly recommend you take it to the dealership for a software reset/update, as there are a few software quirks that can leave you completely stranded. This happened to me about a month ago on a road trip; fortunately, the local Ford dealership was able to update the software and the car was up and running again.
Reactions: RLW
varuna90
Pleasanton CA
Mach E
There were several warnings. However - the car is runnning fine now. I drove around 100 miles after this and it seems all normal. I will likely take it to the dealer tomorrow or day after
Ford Motor Company
Official Ford Account
I called Ford road side and that is absurd. No response for almost 2 hrs.
Then somehow being an IT Windows guy, I tried to do a hard reboot (Pressed power button for 1 minute) and suddenly power is back and it starts to work again.
My service guy is saying to try for 1-2 days and then come to them and they will see if they can find something.
Anyone has any idea what could be wrong and is it safe to drive for couple of days?
Hi there! This doesn't sound like an experience we want you to have with your Mach-E. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd like to see how I can assist you on my end.
If you get a friendly service advisor, ask if they can take a few minutes to connect their scanner and pull the codes. They should see an awful lot of orange and red boxes. Clear the codes and then run a full self check. All those boxes should come back green. If not, then perhaps there is a SSM or TSB available for that issue. It will depend on which module(s) fail to clear.
If you are lucky, then everything will be green and you can be on your way. ?
machme
22 GT
Good write up!
