ARK
- Aug 21, 2020
- Los Angeles
- Mustang Mach E
The breaker in the main panel has a “60” on it. Picture below. I’m also posting a picture of the full wiring, it goes only a few feet from the panel (located immediately on the other side of the wall) to the outlet. Does the box with the outlet in it look like it may have been set up that way? He definitely changed it to a 60 amp breaker in the main panel after the inspection, lol.Is it possible that outlet is on a 50 amp breaker installed in the same box the outlet is in? The picture you provided looks like some sort of subpanel so maybe he ran a 60 amp circuit for a direct wired charger, and ran the outlet off a 50 amp breaker in that subpanel. If that is what he did, you are in good shape. That is exactly what I did, BTW.
