Clicking sound while turning
Larry Paul
Larry
MME-GTPE, Sunbeam Tiger w1970 Boss302, 2002Rav4EV
So it sounds like my diagnosis is correct - it is a CV joint, but not because of a torn boot or lack of grease. It is a design that needs to be improved upon on early cars?
Neil4Real
Not sure if it has been improved though. Seems similar to the brake pad/rotor TSB, it still happens on cars outside the range and cars within the build date range have the issue multiple times, so the replacement isn't any better.
cjljr41
Chuck
Windsor, CT
'24 GTPE, '21 Premium 4X (traded)
I had my driver's-side axle replaced twice, and the passenger side replaced once. I have 21,000 miles.
Print out the SSM and hand it to the service guy when you drop off the car. I had the same problem and they replaced both half shafts under warranty about 10,000 miles ago. Since then, no recurrence.
Ford Motor Company
Official Ford Account
I have a MME-FE Job 1 with 18k miles. For the past month, I've heard a clicking sound when I turn the car around a corner. I only notice it at slower speeds (under 15) and the tighter the turn and the faster the turn, the louder the clicking. It's most often heard when taking off around a corner from a stop.
It sounds like it's coming from the wheels and the clicking 'rate' is perhaps 6-8 per second for the few seconds of the turn. As soon as I straighten it out, the clicking stops. I don't hear it at higher speeds and gentler turns.
Any thoughts on the source of the noise?
Hi Sean. Can you send us a DM with your VIN and dealership info? I can look into this for you.
shadowsjc
NJ
Ive had the same issue for almost a year. I took it to the dealer last summer and they said they couldn't find the parts to fix it. Took it again last week, they said the noise was normal. Absolutely the worst customer service
rgreene
Ryan
Tustin, CA
Mustang Mach-e GT-PE
I gave up on this issue with my car. I had clicking and after over a month of the dealer not being able to figure it out, they just decided it was the tires making noise and gave it back to me. Not going back to that dealer again.
santa fe,nm
www.envirokarma.org
Solar Sales/install
I dunno if it was a design problem, or a run of bad parts, or a period of assembly that may have had production/assembly issues.
CarboFE
Minneapolis, MN
Mustang Mach-E FE Carbonized Grey
Just got my '21 FE back from the dealer. They are waiting on parts to replace both front (half?) axles due to "creaking" (my description) in the front end while turning. Will update when complete.
santa fe,nm
www.envirokarma.org
Solar Sales/install
Can you let us know what your Dealership had to do to get this remove/replace authorized so parts could be ordered and service done under warranty?
Was Dealership Service verification of 'creaking/clicking/clunking' all that was required?
That's all my dealer did. And then they gave the car back to me while we waited for the parts to come in.
Aggie PT
Texas
Honda Accord
I started hearing a clicking from the front while backing out of my work parking spot or garage a month ago or so while turning. I have a 2022 premium that was built in October 2022 and now has less than 2k miles on it. Is it possible to have this issue based on the clicking sound I'm hearing, the build date and the low mileage?
This is really disappointing if so, since I came from a Honda Accord that basically had zero issues for 16 years.
It would be surprising if the issue with my car was also present in your car, built more than a year later. It is probably something else, or maybe nothing to worry about at all.
