Door Fault service required notification
AutoReverse
Alan
Fishersville Va
2023 Mache GT
First of all I love my 23 mache gt. Got a door Fault service required. Push ok and it goes away until I restart car again. Dealership says they can not find a fix for it. So now they are going to try using recent updates to find a fix. I know it's early yet but I'm getting this sinking guy feeling if you know what I mean. Has anyone else had this issue?
Ford Motor Company
Official Ford Account
Hi there! Will you send us a message with your VIN and your local Ford dealer? We'd like to investigate this door fault concern on our end. Thanks!
Kevstone
Kevin
Uk
Mustang Mach-E AWD X
I hope Ford can help you with this. I have had two Mach-Es and they have both had this message. In both cases my dealer knew what to do and quickly fixed it with a new part.
Scottie’s MachStang
Scottie
Gulfport, FL
Mach-E premium ext
I sell Fords
Mine is in the shop for this error message RIGHT NOW. They are replacing one of the door latch mechanisms.
SalsabyJake
Jake
2023 Mach E Premium
Musician
My driver door latch failed last week, Tuesday. I heard a sound after I opened it and it was thereafter dead. No light, no function (had to open from inside).
The door latch module was the culprit and they also had to replace the fuse supplying it. The part took a day to come in and the overall fix, with a Charge Port recall software update took 2.5 days. This is kind of in the too complicated for reliability category ;)
NOTE NOTE NOTE: In my case the car was certain that the door was still open, even when closed. This made driving it very tricky. After initial warnings about the door fault, it would complain any time the car came to a complete stop: "Transmission not in Park, Parking Brake On".. SO IT ACTIVATED THE PARKING BRAKE automatically at any full stop. You have to press the foot brake, turn OFF the parking break, and then you can hit the accelerator to move. Once you get the hang of it, not too bad. But I got stuck in traffic the first time until I figured it out. ;)
GoingGreen
Bruce
CT
Outback, 22 MME
My car is also in the shop for the same issue. My one peeve is that anytime I bring my car in for warranty service it takes two days. The first day to confirm there is an issue and order parts and the second day to recieve the parts and actually perform the service.
Teslaeata
Nottingham, England, UK
Right rear door catch faulted after my HVBJB recall. Cost over £500. Just WHY can’t they find the problem??‍♂
AutoReverse
Alan
Fishersville Va
2023 Mache GT
VIN 3FMTK4SE7PMA56818
Dealer is Campus Ford Waynesboro, VA
Phone 540 208 0817
Thank you for anything you do.
leeman
Outer space
2021 Mach E GT
Something tells me these door latches are going to be a problem in the future owning a 2021. I can see that happening soon. They are just inexpensive plastic.
snowdoggie
Hal
Walnut Creek, CA
Volvo, Nissan, Audi 2017 SQ5, MME GT, M3
IT Operations Manager
I just got the same error randomly today. I do notice the driver door unlatches put the motor afterwards is delayed a few seconds and sounds weaker than the other doors
Ford Motor Company
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
GioVonGio
D.C. to Norway
2022 Mach E4
DOD
2022 ME AWD. I am getting the same fault as well with no problems with the doors.
I fear I’ll be charged to have this taken care of and I’m not happy about it.
hoping the collective intelligence of the group with find a fix that the layman can fix this mess himself.
3FMTK1SS8NMA18869
Thesnowback
Andy
Ada, Michigan
2023 Mach-E GT | 2021 Shelby GT500
Business Owner IT Consultant
I had this issue a few months ago. Dealer fixed it quickly said it was a loose ground.
Ford Motor Company
3FMTK1SS8NMA18869
Good morning! I can take a closer look into your door fault concerns should you need further assistance. For security reasons, just send us a DM with your VIN and dealer name/location, and I'll get right on it. To send a direct message, just click on our username and select "Send Direct Message". Thank you!
PS20221
Paula
Hyundai Santa Fe, ordered MME premium, x rwd, in carbonized grey
Thank you for this tip! The same exact thing is now happening to me. Hopefully Ford makes this right.
