E Heat Question
Without e-heat would I be correct in assuming the only heat would be that which is produced by the battery system or are the two completely different coolant loops and not shared?
The HVB and cabin heater share the same fluid. In theory the battery heat could be used to warm the cabin but I don't think it is very effective. Winters are mild where I live so I don't see any signs of that happening on my car.......except when I was coming down a mountain yesterday and I noticed the air coming through the vents was getting warm. I switched to Whisper to reduce the regen and the air temp matched ambient again. So, I think the battery might have been getting a little warm and somehow sharing some of that heat with the cabin.
I doubt there would be much heat while driving on normal road conditions.
The motor, inverter and electronic units generate heat. But not sure if that would have or has any noticeable impact on cabin heating.
The motor and electronics are on a different coolant circuit. The workshop manual says in at least two places that heat from those items can be shared with the cabin/HVB circuit but I don't think it is correct because I could not locate a valve or separate heat exchanger that would accomplish that task. ???
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
I've had this car six months I didn't notice the E-heat button til I read this, I've just always used the auto mode.
5 months for us and I don’t think the heat has come on yet? Turned off the AC for a while but didn’t notice any difference in range.
zvez
chris
ga
To be fair, searching a pdf in order to locate a topic doesn’t require one to read the entire manual.
Been thru the manual more than I'd care to admit, 400 pages with a lot of useless stuff and amazingly no information about jacking points of the car or even how to properly tow or tie down the car, which someone was kind enough to post a pic of from the service manual.
ARK
Los Angeles
'21 Premium SR AWD
The motor and electronics are on a different coolant circuit. The workshop manual says in at least two places that heat from those items can be charged with the cabin/HVB circuit but I don't think it is correct because I could not locate a valve or separate heat exchanger that would accomplish that task. ???
Sometimes it’s hard to trust the manuals they put out, the owner’s manual has multiple references to an ‘engine’, if such an obvious mistake made its way in, it makes you think what else is in there that’s incorrect that might not be as obvious of a mistake at first glance.
phil
LS400
Not a mistake. Just normal English usage.
en·gine
/ˈenjən/
noun
  1. 1.
    a machine with moving parts that converts power into motion.
TheCount2
Marc
NJ
'21 Select with BlueCruise Job 1 21P22 SW Update
Actuary
From the manual it says if you want to cool your cabin, set to Auto. If you want to heat your cabin , set to Auto. Both EHeat and AC comes on to do what it needs to do and hasnt failed me yet.
Ford recommends that you use the seat heaters and the steering wheel heater, which both geneate heat. Turning on the E-heat has an almost immediate effect on the reported range of my vehicle If it is off, the range gradually increases.
jonnyboy7
Berkeley, CA
Mach E
Assume my HVAC is set to “auto,” E-Heat is on, and the ambient temperature is higher than my chosen auto temp setting, resulting in the HVAC only cooling. Does the fact alone that E-Heat is selected have an impact on range?
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2023 MME
I have taken to turning e-heat off a few minutes (90+ seconds maybe) before turning the auto/climate off to allow what heat is left in the system to continue warming the cabin, ymmv.
It is resistive heat. If it's putting out heat, it uses electricity. If it isn't needed, then no, it's not using electricity.
