Electrical System Drain Message
ChuckA
ChuckA
Chuck
North Branford, CT
ā€˜21 MME Premium AWD ER in Infinite Blue
Accountant-Retired
I am going to try this: Instead of the *vehicle* having the charge schedule I will set it to "charge whenever plugged in" but make the Chargepoint dictate when it charges on the schedule. Perhaps that will stop the EVSE from pinging for charging data while it's plugged in since it has more inherent information about the session.
If you use ā€œcharge whenever plugged inā€ it will ignore your other settings and charge to 100% SOC.
Stang68
It still allows me to set a charge limit.
Ford Mustang Mach-E Electrical System Drain Message IMG_3363
Rather than starting a new thread, I’ll piggyback off of this one. To start, I have a MY21J1 Premium AWD ER. I do not have ANY aftermarket accessories (and specifically, NO Electrical accessories like dash cams, illuminated ponies, koi pond aerators, etc.) Got in the car this morning to be greeted by a dialog on the IP that said ā€œElectrical system drain. Service required.ā€ According to Ford.com, my battery (presumably still 12V) is at 61%.
Went into FordPass and saw the two messages below. So, the big question: am I ok to drive around this weekend until I can schedule service?.
Ford Mustang Mach-E Electrical System Drain Message IMG_1276
Ford Mustang Mach-E Electrical System Drain Message IMG_1277
Ford Mustang Mach-E Electrical System Drain Message IMG_1278
agoldman
Charleston, SC
I just received this meessage and have no 3rd party devices or apps running other than Ford pass. no idea what could be causing this and wondering if it's safe to drive to the dealer.
Anything plugged into the OBD port?
kwlinder
Northern VA
2022 Mustang Mach-E GT
I just got the same messages here on my phone 9:09pm EDT. Nothing plugged into the OBD port, nothing in any of the USB ports. First time I've ever seen the message since I got the car in July 2022.
I hadn't plugged it in for the night yet, but was plugged in last night and it was driven 50 miles today. When I logged into my dashboard on the Ford site, battery was at 65% SOC. Went to the garage and plugged the car in, and looks like the 12v battery is charging, up to 76% after just about 20 minutes.
Only difference between yesterday and today was that I did have the 24-PU0301-BLM-PE update (Entry Made Easy) installed last night... ?ā€ā™‚
phil
LS400
Probably. I got the same messages, repeatedly, a few weeks ago. Then they stopped. I took the car in for the indicated service, but the dealer said they see nothing wrong so they did nothing. They said to bring it in if I get the drain messages again. Not very comforting.
agoldman
Charleston, SC
could it be related to the recent battery/charging ota patch?
I got this error again this morning ? I guess I’m going to be talking to the dealer tomorrow.
agoldman
Charleston, SC
mine cleared after charging to 100 percent overnight. not sure what's with this message. charge level now says 63 percent. maybe if yge charge level goes took it throws the message, but that isn't a reason to alert the customer to go to the dealer. I wish we had better user information. it's all over the place....
Check that:
  • No dashcams or radar detectors are wired into the electrical system
  • No devices are plugged into the OBD port under the dash
  • No hidden dealer-installed tracking devices are installed
  • Welcome lighting is disabled
  • You have not ever given your FordPass password to a 3rd party app
    • Change your FordPass password to be safe
  • No rodent damage to wire harnesses has occurred
  • No faulty EVSE that causes charge faults
Hey, thanks for the reply! Actually, I think it may have been somehow associated with the headlamp switch. On Sunday morning, I noticed that none of the LEDs on the switch were light (I always keep the switch in Auto). I rotated the switch, and an LED lit, so I went through all positions, confirming the associated LED lit up, then went back to the Auto setting (and the LED is lit). No errors or issues this morning.
See answers below:
Check that:
  • No
  • No. I only put the OBD reader in when I’m using it. Otherwise it stays in its case in the console.
  • Not that I’m aware of
  • Welcome lighting is ENABLED.
  • No, it’s stored in my Keychain and that’s it.
  • None visible
  • I use a FCCS. No indications of error on the device or in FordPass.
ShaggySS
Scott
Roseville, CA
2022 Mach-E Premium RWD
IT Nerd
Same boat, wondering if where I keep my key inside the house is now triggering welcome lights. I moved mine further from the car. Just a thought
Vgkfan
Keith
Nevada
I checked my Lvb last night since I was scheduled for this update early this morning. It was 82%. Haven’t been in car yet, but I know I got 24-pu0301-blm-pe installed. Just checked my Lvb,and it’s 65%.
