Same in Switzerland… 3.23.0…. But at least PaaK works flawlessly on IOS… ?In the UK we have V3.23.0
I have been checking charging to ensure it is working and before that to make sure the 12V did not die again. I do not really like the fact that is is so unresponsive when powered off. I wonder what the BMS is doing when it is in that deep of sleep.3.25
All the comments are to 3.25. It was pretty much fine until that update to FordPass. I also don’t generally have FordPass running though unless I’m using the car or will be shortly.
Fix? I've never once received a notification like that. I heard the recent OTA update (Ford Power-Up 1.4.0) might allow that feature to work as expected. I haven't received it yet so I can't confirm it.Does this fix the constant notice of your car was walk away locked?
Is that considered a bug? I never considered it terribly useful, but it always amused me how rock solid reliable that notice was when so many other things didn’t work. I wonder if that particular notice is being sent to the phone directly through Bluetooth because the phone is still in range while walking away, and that’s why it is so much more reliable?Does this fix the constant notice of your car was walk away locked?
Start by checking the app’s Settings -> Notification Settings. If all that is enabled, you probably need to do a Sync master reset. Beware though, this is kind of a pain in the ass because you’re going to lose all your settings and PAAK keys and have to set everything up again.Fix? I've never once received a notification like that. I heard the recent OTA update (Ford Power-Up 1.4.0) might allow that feature to work as expected. I haven't received it yet so I can't confirm it.
I did not get the walkaway notice until I had the recall completed. It started immediately once that was done.Start by checking the app’s Settings -> Notification Settings. If all that is enabled, you probably need to do a Sync master reset. Beware though, this is kind of a pain in the ass because you’re going to lose all your settings and PAAK keys and have to set everything up again.
I think it was related to that OTA, I had previously completely removed PaaK for about a month, so I was going in fresh and all my settings on Android are good. I only just started using it again with v 3.24.Start by checking the app’s Settings -> Notification Settings. If all that is enabled, you probably need to do a Sync master reset. Beware though, this is kind of a pain in the ass because you’re going to lose all your settings and PAAK keys and have to set everything up again.
That makes sense. I was scheduled to have that done tomorrow but I canceled it. My dealer said they would need my car for 2 or 3 days to do this. That was enough for me know they way too busy and probably don't know what the hell they are doing, so I'm playing it safe and waiting for the OTA.I did not get the walkaway notice until I had the recall completed. It started immediately once that was done.
Plus it popped up when I locked with the dam button. It makes no sense. I have now turned off all notifications.Is that considered a bug? I never considered it terribly useful, but it always amused me how rock solid reliable that notice was when so many other things didn’t work. I wonder if that particular notice is being sent to the phone directly through Bluetooth because the phone is still in range while walking away, and that’s why it is so much more reliable?
yup.I did not get the walkaway notice until I had the recall completed. It started immediately once that was done.
