e-pony
SoCal
Premium AWD Extended Star White
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
Super. Thanks. Dark blilue text on black bacground is not readily visible.. for ex., the 12V Battery value is difficult to read.
Z-one
Chicago
2022 Mache GTPE
Can someone help me with what I am doing wrong. When I go to advanced info the OTA data has a lot of null data, if I go to "view more details" it is all "not available" and if I go to "view module infor" clicking get data does nothing. The main widget seems to work.
Thanks!
Neil4Real
Thanks!
I'm getting the same with OTA data, but I believe that is because I last received an OTA on 2/14 and it clears after 3 months since that's how long Ford stores that info on their server. Do you know when you last got an OTA update?
Z-one
Chicago
2022 Mache GTPE
Not sure I just took delivery a few days ago.
Goober96
Brent
SC
2021 Mach-E4X, 1996 Mustang Cobra, 2008 Corvette
The dashboard works great but the widget has become useless because it doesn’t update anymore.
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
I just upgraded to the latest version. I don’t see the location of the car displayed anymore. Does this mean that I can no longer use the widget to track my Wife? Lol
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Software Developer/System Admin
Lmao
Nothing was removed on my end
stmache
Scott
Leesburg, FL
www.sthomasphotos.com
2023 Ford Mustang Mach-e GTP
Photographer
I broke mine. Do I delete the Scriptable app and start over? When I run the Fordpass Widget script, it spins for a couple of seconds but won't open. Using iPhone on latest iOS version.
Deleted member 4170
Guest
OK, I just released v2022.05.12.1
Hi Tone, I had the widget working great but got an 'update available' message a couple of days ago so updated!! Now widget is frozen and if I refresh I get a failed message and fsw files saved. I'm using Android on Sumsung S20. Have attached the Fsw file.
Cheers
Ian
ktn
Current: F150 Lightning SOLD: 2022 Mach-E Premium ER AWD
Cheers
Ian
Yeah it’s been really glitchy since the last update. Large Detailed doesn’t really work for me anymore.
Cheers
Ian
You‘re running the iOS widget on Android?
kennelh
Louise and Ken
Northern California
Cheers
Ian
You're running the Android widget, not the iOS one.
