SAM
SAM
Central NJ
Premium MME4X Iconic Silver
New Release: v2022.02.21.0
I just pushed out a new release which hopefully gets the large widgets working more consistently.
Please let me know the outcome!
Thanks for the update. Large widget still not working for me but color mode (light/dark) is working. Medium size widget is the only one that will display. Although the small and large widgets appear in the window when selected with "View Widget", the size is not updated on the home screen.
Matstar
Canada
Mach E Premium
It doesn't work for me. I uninstalled and still not able to see the Widget on the home screen. But I see it when I open Scriptable.
But no photo of the car and error message that the image is missing.
Do you have a solution?
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) IMG_3421
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) IMG_3422
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) IMG_3423
I’ve been unable to update from 1.x. Following the video instructions results in literally nothing happening. Deleting the old script and starting from scratch? Same thing. Nothing happens. ?‍♂
Just a FWIW update. The issue I had was an iCloud issue. After resetting and cycling virtually everything it all returned to normal. Just in time for the large widget.
Neil4Real
Thank you so much! I'm lovin' these and the smaller widget is awesome. When I click the widget, I have it set to 'Run Script' just like on the old version. But it seems to take a long time now once it opens Scriptable and runs the script for anything to open. Is this just because there is so much more data/controls?
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Software Developer/System Admin
Yes, it's because there is more data and logic to process now.
I might allow it to load from cache on first open since it updates the dashboard every 30 seconds anyway and just have it perform a quick refresh within a second or two of displaying the dashboard so the data is current.
SAM
SAM
Central NJ
Got the large widget working. Updated to current version (2022.02.22.0). Deleted home screen widget, deleted Fordpass widget in Scriptable, added Scriptable Fordpass widget back by running Widget tool. Added large widget to home screen and selected Fordpass script in Scriptable. Large widget remained generic. Opened Fordpass widget in Scriptable, selected menu and "View Widget". Selected Large Widget (Light), closed windows and large Fordpass widget appeared on home screen.
I really don't know what I did to make it work. A lot of steps somehow worked.
SAM
SAM
Central NJ
Looks fantastic!
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) IMG_1205
Bonehead
Malibu
'25 MME GT Performance ('21 MME Premium AWD Ex)
Crazy - I was about to post that I've been unable to get the large widget even with the update, and just got the error message below, but now it's finally working!
Thought I'd post it anyway since it clearly has something to do with the issue.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) My Photo Stream - 1 of 1
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I pushed out a fix today for this and other bugs.
Neil4Real
Not sure if you ended up doing this already, but holy smokes, it’s almost instantaneous now!! Thanks
smartino
Indiana
2021 RR Mach E First Edition, 2017 Honda Ridgeline
Since the last update I’m noticing the following:
1. Cannot get the large widget to work, it was working before the last update.
2. Medium widget works but seems to take forever to update. See the screen shots. The widget update was from 8am this morning and has t updated since.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 7ED9328D-C432-4280-B775-BB15EDDE06DE
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 08FDBFCA-E7CF-4B43-B463-C6FB2A13B7E9
Could the change to using cache be causing this issue?
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Everyone else is telling me their large widget works much better now. There seems to be no reason to have these issues. The cache change only affects the dashboard menu.
smartino
Indiana
I’ll keep trying. Thanks
