bulltanner
Gray, Ga
2021 Ford Mach E Premium Standard Range AWD
Area Manager
I love this widget an thank you! question, is there any way to make the widget send phone notifications when charging is complete and MORE SO when there is a charging interruption? I have had more "Charging Paused" messages happen in the middle of the night that I am unaware of and find my car half charged when I wake up. Just curious if it is possible. Thanks in advance.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Absolutely!
All I need are captures during the various states. So please send using the diagnostics section of the Advanced info page. You can send me multiple emails (just make sure to add a note so I know which state is which)
kennelh
Louise and Ken
Northern California
Absolutely!
FWIW, these are the values I've observed in vehiclestatus.chargingStatus.value: "NotReady", "ChargingAC", "ChargingDC", "ChargeTargetReached", "CabinPreconditioning", "EvsePaused"
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Appreciate the values!
Is it safe to assume that "EvssePaused" means it was interrupted?
kennelh
Louise and Ken
Northern California
Is it safe to assume that "EvsePaused" means it was interrupted?
I would agree. I just plugged in my ChargePoint Flex and the value went to "ChargingAC", but then told the EVSE to stop charging and it changed to "EvsePaused".
Neil4Real
It means that it was paused by the charger, not the car. I'm not sure if there is another value for interrupting the charge session with a straight unplug or something. Maybe it uses the same value for both circumstances.
New today, started after 2.5.1 installed. Tried an update, restart etc.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) DB011C4B-03B0-4531-AB02-FA098890F330
smartino
Indiana
2021 RR Mach E First Edition, 2017 Honda Ridgeline
Run the Ford Widget Tool and reinstall the instance, as that has corrected this error for me in the past.
I just started getting this exact same error. 2.5.1 dropped yesterday.
Any word on the broken widget tool? ???
minjaep
2022 California Route 1 eAWD
What does it mean by "DF" for doors?
The widget shows the car's status as doors "DF" and locks "unlocked", but it is right after I shut off the engine or lock by Ford Pass or fob. Apparently something is wrong -- while other information/numbers seem okay.
Also, I don't see "Advanced Control" as in the screenshots. I follow the latest instruction so not sure what I should do.
DF is the Driver's side Front door. The problem is that the car updates its status when you open the door to get out but then doesn't update its status again after you shut the door and lock it. Mine does the same thing.
