Logal727
C
DF is the Driver's side Front door. The problem is that the car updates its status when you open the door to get out but then doesn't update its status again after you shut the door and lock it. Mine does the same thing.
Yeah, this is what has made glancing at this to check if it actually locked the doors not actually useful. Whether it’s the HomeKit integration or the widget, it doesn’t give an accurate status all the time.
Yeah, that’s one of my pet peeves with the car. I really wish it would update its status without having to be woken up, even if it’s only once an hour or something. For a while, there was verbiage in the “your car is asleep” message that said that there would be an update that would allow the car to report its status even when sleeping. That verbiage was later removed, so not sure if that‘s ever going to happen.
Is the widget fixed yet?
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) B3F6AB54-F4F9-49FC-A889-705B45E2F028
I fixed it. I went into WidgetTool and selected “Create New Instance”.
I’m also in Beta mode
Neil4Real
Its weird, because I was never getting the driver side door open notification in Ford Pass on the main screen, but now I do and it takes forever to clear. I wonder if a server/Ford Pass update changed this? But it is definitely annoying that the widget tool, which is no fault of the widget tool since the car doesn't update like you said, just shows the car unlocked with a door open for hours. It is also dumb that FP itself doesn't tell you if the car is locked or unlocked! Seems like it would be so easy to just highlight the Unlock and Lock "actions" in FP so you know that's the current status.
Done that (repeatedly). Same results as before. Frankly, I've given up on the widget for now.
Sorry to hear. Setting up a new instance worked for me. Perhaps blow away the scriptable engine and start from zero?
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Wow. Sorry I missed these. I stopped receiving notifications here.
Use the widget tool to remove the instances and it should remove all saved data as well
