FORScan MME spreadsheet
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
The venerable Livnitup has graciously created a spreadsheet for the Mach-E. It only has a few modules at present, he will add more as he finds time. It is MY23, not sure of any differences with 21/22. The 2-press panic button mod worked for me.
Mach-E spreadsheet
21st Century Pony
Martin
Arlington, Virginia
Nice! Thank you both!
Holy smokes, I can't read it. What 2-press panic button mod did you do?
It makes the FOB take 2 presses to activate panic vs 1?
byoungblood
Bart
Berryville, VA
2012 F150, 2007 Mazda 3, 1999 Jeep Wrangler
I can confirm that you can disable the panic alarm on a '22. Good riddance!
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
Is there a setting in there to disable the speaker beeping when backing up ?
Or maybe lowering the volume somehow ?
I am not sure what to look for actually
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force (ret.)
There's no way to do it within the logic of the vehicle modules. It can be done manually. There's a few threads on it. You can make it worse by having it chime inside the vehicle as well as outside...? It's a bit in the IPC module.
Edit. You can prevent the IPC from detecting that that PACM exists, thus preventing it from warning of an issue, but you still have to physically disconnect it, pull fuse or disable speaker. It's a pain in the ass to pull the fuse or disconnect the PACM due to removal of panels.
i8iridium
Pat
Fort Washington, MD
This is also fun...the Auto high beam ramp up that the later 22s and 23s have. Got it working on my early 22.
734-01-01 xxxx xxx1 xx--
734-01-04 00BC 1612 <-have to change your value to match this, or you'll get a headlight system error.
Tried it out and it works perfect. I have no idea what it'll do on a '21. But you must have a higher trim with the LED Projectors, otherwise there isn't a headlamp control module (HCM).
LaFong
LaFong
Colorado
Systems Engineer
Yes, the fake speaker route is easier. Though you will lose your fake engine noise too, if you like that. https://megaohmmotorsports.bigcartel.com/product/ford-psbk-ece
LaFong
LaFong
Colorado
Systems Engineer
Thank you, i have ordered the kit !
Cool. Actually I think the low-forward-speed sound in this speaker is again for pedestrians and is unrelated to the fake propulsion sound.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Nice so instead of high beams on or off they slowly come on? Will have to try this.
