FORScan MME spreadsheet
Chainspell
Erich
Sacramento, CA
'21 Premium 4X, '23 GTPE
I would love to see steering wheel temp setting. My '23 GTPE steering wheel heater is WEAK.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Anyone know what the differences are with memory and which is active in Mach-E?
Memory_Type_Cfg (MTC)
726-27-01xxxxxxx*xx--0 =MTC ADVANCED_CLASSIC_MEMORY2 =MTC ENHANCED_MEMORY
1 =MTC CLASSIC_MEMORY
w0ger
Roger
Minnesota, USA
ā€˜26 Rivian R1T, '23 Mustang Mach-E
Looking at the config of my '23 MME Premium Ext Battery, it has 2 = MTC ENHANCED_MEMORY.
Not sure what the differences are.
Devbloggs
Alberta
2022 Mustang Mach-e Premium AWD extended
Mechanic
Neil, I have a 2021 Job 2 and it works perfect. You need to change TWO lines in the HCM
734-01-01 xxxx xxx1 xx-- Change the last digit in the second set to "1"
734-01-04 00BC 1612 Change both the first and second sets of digits to "00BC 1612"
So, would this make the high beams gradually turn on and off, instead of simply on and off like most vehicles?
markboris
Sonora, CA
Basically yes. They will gradually turn on (2 seconds) but the turn off is about 1 second. This is when it is in the auto high beam setting. If you use the stalk to flash your high beams, it will be an instant on and off.
Devbloggs
Alberta
Mechanic
Awesome, did what you had posted, no DTC's and works perfect
I think a Lincoln or something had this driving towards me once
Kinda nice that it takes a bit to hit the high beams, nice for when they really shouldn't have turned on
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Asking the smarter folks in the room. I tried to follow this on my 2021 job 2 GT. And I got a checksum error. Does anyone see what I did wrong here?
Ford Mustang Mach-E FORScan MME spreadsheet 8B96791B-2503-4F22-A7D3-233DD70FC9D6
original config^^^^
Ford Mustang Mach-E FORScan MME spreadsheet CEDE276C-226C-4A4E-A01C-7C99505423C8
my attempted changes ^^^^
Ford Mustang Mach-E FORScan MME spreadsheet 612490DB-5CC0-46E5-B202-52FA23006FE8
The error I received. Maybe I’m supposed to acknowledge the error and write it anyway. But I’m being a chicken?. First time I’ve messed with Forscan at all and I’m terrified.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
I clicked yes and had no errors.
Thank You. I went ahead. The car did not explode. I’ll have to check for ramping headlights once it gets a little darker.
original config^^^^
That’s normal since you changed the configuration.
markboris
Sonora, CA
That is normal on some configuration changes. Like others said, you should be good to go.
Blue highway
Oregon
Mach E Premium SR RWD
I haven’t seen any Job 1 owners try it. It’s on my list, but haven’t gotten around to it yet.
:) if any job 1 owners tried this, I'd have bet it would be you. If and when you do, pls post.
Thanks
Do we know when this was an installed feature, where the cutoff is? I have to say that I am not sure how our 22's headlights behave.
