FORScan MME spreadsheet
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
I had the same problem. I contacted Forscan - they asked for my VIN and sent me a new version which worked. They were good to deal with.
Lou
Yes, it seems support for every trim needs to be added separately. I got a version for the GT. Two other people got versions incorporating GTPE and Select. Now comes Premium. I would assume CaR1 is another one. They were very quick. You might want to post the link when you get it.
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
This is also fun...the Auto high beam ramp up that the later 22s and 23s have. Got it working on my early 22.
734-01-01 xxxx xxx1 xx--
734-01-04 00BC 1612 <-have to change your value to match this, or you'll get a headlight system error.
Tried it out and it works perfect. I have no idea what it'll do on a '21. But you must have a higher trim with the LED Projectors, otherwise there isn't a headlamp control module (HCM).
Isn't this a default setting on our European cars ? I am having trouble understanding the added value here ?
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
This was not standard on North American cars before mid 2022 models. European headlights are different than ours.
21st Century Pony
Martin
Arlington, Virginia
I did the HCM high beam graduated dimming mod yesterday and tested it last night. Works well on my March 22 Tech Package Premium. Neat feature.
At first after executing this quickie mod, I thought it is a nice novelty item. Now after driving with it for several nights, i appreciate it more and more. It just "feels better" and the way the camera and the lights now work together is far less abrupt and (maybe) also better for drivers facing me in oncoming traffic. The light transitions are really good in their intensity and in their reaction time. Very classy.
SpaceEVDriver
Planetary Science
Does anyone have Electric Efficiency Cluster IoD config (EECID) configured to be enabled?
7D0-10-01xx*xxxxxxx--
2 =TTCID Disabled • FECID Disabled • EECID Enabled • EBCID Disabled
I haven't played with editing any configurations in FORSCAN yet, but this is one I'd consider, if it enables mi/kWh on the IPC. I don't know enough about all of the codes to know if this is an accurate guess about the result of changing that setting.
Thanks!
LaFong
LaFong
Colorado
Systems Engineer
Thanks!
I enabled it (set it to 2) and…nothing. No DTC errors but I don’t see anything different.
SpaceEVDriver
Planetary Science
Thanks for testing it!
byoungblood
Bart
Berryville, VA
2012 F150, 2007 Mazda 3, 1999 Jeep Wrangler
Since the module that controls BC is available in FORSCAN, has anyone looked to see if there is a way to reduce/eliminate the "WATCH THE ROAD" nagging?
Some days it seems like the slightest obstruction of the sensors has it going off non-stop. I'm staring at the road, but it goes nuts because it doesn't have a clear view of my eyes. If there was some way to add a few more seconds delay onto the nag would be sufficient.
I've turned off the lane keeping system numerous times just so I can eat something without the car going nuts. @Ford Motor Company tell me how that is more safe than programming a few seconds more delay into the nag?
LaFong
LaFong
Colorado
Systems Engineer
Possible setting from F150 spreadsheet, CMR module (Camera Module Rear [Driver Status Monitor Camera]). Mine is set to 8. This assumes "DR" means Driver Recognition and not Data Recorder. Whether that would affect Blue Cruise operation in other ways is a question.
7C1-01-01
xxx*xxxxxx-- EDR feature enable or disable configuration (EDR)
• Camera pose correction (C)
• Camera out of position detection (C)
• Steering Wheel Configuration (SWC)
0 =EDR Disabled • C Disabled
• C Disabled • SWC LHD
8 =EDR Enabled • C Disabled
1 =EDR Disabled • C Disabled
• C Disabled • SWC RHD
9 =EDR Enabled • C Disabled
2 =EDR Disabled • C Disabled
• C Enabled • SWC LHD
A =EDR Enabled • C Disabled
3 =EDR Disabled • C Disabled
• C Enabled • SWC RHD
B = EDR Enabled • C Disabled
4 =EDR Disabled • C Enabled
C =EDR Enabled • C Enabled
5 =EDR Disabled • C Enabled
D =EDR Enabled • C Enabled
6 =EDR Disabled • C Enabled
E =EDR Enabled • C Enabled
7 =EDR Disabled • C Enabled
F =EDR Enabled • C Enabled
byoungblood
Bart
Berryville, VA
7C1-01-01
I'll give it a shot, thanks.
I'd say that maybe one in 50 of the "watch the road" nags I get are from me actually not watching the road, and usually that's because I'm dealing with an unresponsive/lagging press to the center display. Other 49 are from the sensor getting blocked by a hand or other object.
LaFong
LaFong
Colorado
Systems Engineer
CMR module added to the spreadsheet, seems to be the same as the F150.
LaFong
LaFong
Colorado
Systems Engineer
I've been waiting for the VDM to show up. ?
Not sure whether you’re joking. VDM (721) is not a Mach-E module. At least, it's not in my '23 modules.
Vehicle Dynamics Module (VDM) is a Mach-E module, it controls MagneRide. It may not be supported by FORScan yet.
Yes, I have been waiting for FORScan to include the VDM for my car so I can tinker around with it. ?
