FORScan MME spreadsheet
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
My apologies for typing this is someone else asked already, but I've used ForScan before on my wife's 2017 Expedition to turn off that annoying double honk when the car is on and you get out of the car and close the door... not having it is amazing, and I forgot how annoying it was until my 2023 MEGT did it at the dealer.
Do you have the code or number to switch this annoying thing off?
Looking forward to Trying the high been fade thing.
Nice work. Love this community!
https://www.macheforum.com/site/thr...le-honk-with-mach-e-running-in-forscan.11374/
Niceco
Niceco
Albania
Mustang Mache e
The venerable Livnitup has graciously created a spreadsheet for the Mach-E. It only has a few modules at present, he will add more as he finds time. It is MY23, not sure of any differences with 21/22. The 2-press panic button mod worked for me.
Mach-E spreadsheet
Is there a way to change the language of a chinese model to english????I would really appreciate it as im stuck in a sticky situation
LaFong
LaFong
Colorado
Systems Engineer
Niceco
Niceco
Albania
Mustang Mache e
LaFong
LaFong
Colorado
Systems Engineer
What way are you referring to?I already saw that thread and unfortunately nothing helpful yet..
On the second page of that thread is a person in UAE who is able to do it. That potentially says it can be done. Maybe they will share information.
Niceco
Niceco
Albania
Mustang Mache e
Yep,i DM’d them.Hopefully can find something!Thanks anyway
BothKindofMustangs
Todd
Gilbert AZ
24 Mustang GT , 24 Mach E
Has anyone changed DRLs or (halos) to All Amber all the time?
Darkhorse/Raptor kinda thing.
LaFong
LaFong
Colorado
Systems Engineer
BothKindofMustangs
Todd
Gilbert AZ
I believe this requires new and expensive hardware, doesn’t it?
not sure thats why im asking. on the bronco for example the halo and the turn signal both come oem white, and of course the turn goes amber. I can change both of those in forscan.
our mach drls are white, and blink amber when turning. Id assume theres an override inside that can make them amber full time. Ill start messing around.
Dysan911
2023 Mustang Mach E GT
Technical Software Analyst
btw is there a forscan method for adjusting the steering resistance? I like the lighter feeling of it in the drive mode "Engaged" but like the throttle response and regen on the unbridled mode which as you know switches the steering. .
Unfortunately, no. Wish it was set up like the ICE Mustangs were you can pick and choose the individual settings and create a “my mode”.
crl
VT
2023 Mustang Mach-E Premium AWD
FWIW i had a 2017 fusion sport, which is how i got into forscan mods to begin with...and that was able to individually set things like steering mode vs driving mode vs suspension (it had the magna ride) via forscan, so perhaps there is some way in our m-e's
We looked into this three years ago and as of yet, have not found a way. I did do this on my ‘16 Focus RS.
Phobosbag
La
Mach e 2023 premium
I would like to change the brake pedal force required to activate auto hold.
I had a Mazda and the auto hold would only activate with a medium pressure on the brake and stop.
With light pressure and stopping, the auto hold does not activate and I can easily park or pull into a garage.
Now any pressing on the brake and stopping turns on auto hold and to turn it off you need to put the accelerator pedal. This is not convenient.
Does anyone know if this can be changed with forscan?
The amber side marker on the ‘21-‘23 MME Premiums and GTs are physically separate from the DRLs (as evidenced that the DRL stays on when the side marked is active). Not sure that the frequency of the white DRLs can be changed. ?‍♂?
