FORScan MME spreadsheet
anyone know what this this does
D544 Speedometer Style (DSS)
720-05-01xxxx*xxxxx--0 =DSS Style 18 =DSS Style 3
4 =DSS Style 2C =DSS Style 4
It does nothing on our cars.
Eric_C_Boston
Eric
North Shore, MA, USA
Retired Software Engineer
Going by an example I saw to enable BlueCruise, I turned on MFCALB and MFALC yesterday and got the Lane Change and Lane Bias in BlueCruise. Some of the other values were different since my car has GF High Beams. The spreadsheet was very helpful to sort out the differences.
I noticed my 2021 Mach-E has parameters not called out in the APIM for the Mach-E, but are called out in the APIM for the 2024 F150. They are for the Predictive Speed Assist, Speed Limit Assist Tolerance, and the Assisted Lane Change features. I found it interesting that the BlueCruise example I saw had Neutral/Emergency Tow Display Logic enabled and it was disabled on my car. It was also interesting that a zero value does not always mean disabled.
Ford Mustang Mach-E FORScan MME spreadsheet APIM95
Ford Mustang Mach-E FORScan MME spreadsheet APIM1002
rugedraw
Javier
Miami, FL
Auto Sales
I think it may have something to do with 2WD and 4WD models having a different value there, but cannot say for sure that's the case.
MrLoganRoss
Seattle
Mach E
In the spreadsheet I did not find an option to turn off DsP. I replaced the dsp with a complete after market audio system and I was wondering if there is an option to indicate no DSP via forscan. Thanks!
BenW1976
Rhome, TX
2021 Mustang Mach-E RWD Premium
Anyone know how to change our tire size so the speed on the speedometer is correct??
You won't be able to change it more than 1 mph or so. If you go 1% or so outside the parameter of the OEM tire size it will not accept it or it will accept it and nothing will change. Just letting you know.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
1% is negligible. That’s crazy there is a setting for it.
Is there a circumstance difference between the 19 and 20 inch OEM setup?
ave
Finland
Mach-e GPTE '21
Does anyone know what the last byte/2 nibbles of the IPMA 706-02-02 encodes? It is not present in the doc, but in car it is populated and it does change per some other changes.
In ford encoding the field is 706-02-02 xxxx xxxx xx**
tomtel
Tomasz
Poland
Mustang Mach-e GT Performance, Ford EDGE ST
mechanic
is a check number
disimaxi
Massimiliano
Italy
Ford Mustang Mach-E Premium RW
Retrired
I have created a spreadsheet of common Forscan mods. It is very much alpha and not ready for publishing. If anyone wants to look it over, DM me and I will reply with a link.
Hello from Italy, I own a red 2023 ER RW and would be very grateful to receive the link.
tomtel
Tomasz
Poland
mechanic
Hey, I'm modifying my ME GT 2023 and I'd love to see the sheet and I can share my modifications :)
