FORScan MME spreadsheet
ave
Finland
Mach-e GPTE '21
The sheet, as great as it is, is full of acronyms that "make no sense" without the prior knowledge what they stand for.
MFCALB
MFALC
MFCTSR
MFCWWA
MFCSBLM
et cetera ad nauseam
Do we have any glossary as per what all these really are? @Mach-Lee help?
MFCALB
MFALC
MFCTSR
MFCWWA
MFCSBLM
Nope, we don’t know what a lot of those AB features are since there isn’t a glossary posted to my knowledge. You have to Google them or just figure it out on your own.
ave
Finland
Mach-e GPTE '21
Thank you. Feared it would be so. I think we could benefit from documenting everything everyone knows so far.
ngtwolf
Valencia, CA
2021 Mustang Mach-E Premium
Okay, went through this entire thread... Lots of good stuff.
One thing I didn't see and not sure if it's an option, is there a way to disable the keypad lock when driving (where it disables changing features when moving, i also assume the map address stuff is disabled but i don't really use the onboard map)? I assume not, but thought i'd ask.
jav_eee
Javi
Edinburg, TX
2025 Mach-E Select
Energy Industry
Not sure on that but I disabled mine with a product that you just unplug the PWS speaker and plug the device into the harness. It fools the vehicle into thinking the PWS is still connected.
I don't mind the low speed sound. It was just the backup Garbage truck beep that drove me crazy. If there was a way to disable that, I'd only do that. The Device I have takes out both though.
which speaker do you plug it into? Tried looking for instruction online but didn’t find any. Does the product come with them?
Chapron
Detlef
germany
Mach e RWD EX TP2 / 2023.75
SAP Engineer
Hello, I am looking for the code for:
706-01-02x*xxxxxxxx--
when BC ist enabled with ALC.
My 2023.75 had BC from the beginning but I like to add Assisted Lane Change. My PU is 10.2. BC ist 1.1E that means EU Version with BC1.2 but ALC not set because of stupid regulations. I have already set the switch in APIM. My original 706-01-02 is 0600 0000 0016. I fear that I get a checksum issue when I only change to 0500 0000 0016. BTW 0500 0000 0015 enables ALC but does abord actual changing lane every time. Can some one please check his code for the Modelyear with BC fully loaded?
rugedraw
Javier
Miami, FL
Auto Sales
I don't know if the event for lane change assist is included in the 1.1E BC firmware, but check what you have here in the IPMA and change it so that ALC is enabled.
Ford Mustang Mach-E FORScan MME spreadsheet 1754665152710-4a
In line 706-01-02, x5xx xxxx xx-- is correct for US spec vehicles. FORScan will correct the checksum automatically to 0500 0000 0015 when you write the 5 in that location.
Edit: If you car shows 0600 0000 0016 from factory, you need to change that 6 to a 7 to enable ALC and keep ALB & CTASV enabled.
Ford Mustang Mach-E FORScan MME spreadsheet 1754665552622-wl
Chapron
Detlef
germany
SAP Engineer
Thx will try when I M back from holyday.
Chapron
Detlef
germany
SAP Engineer
The 16 as last digits can stay?
jmgreen
Joerg
Germany
Mach-E 2022 RWD-ER
That’s the checksum and will be calculated automatically.
Chapron
Detlef
germany
SAP Engineer
Ok What is CTASV exactly?
jmgreen
Joerg
Germany
Mach-E 2022 RWD-ER
What I know (but I may be mistaken): Cross-Traffic Alert Split-View
The cross traffic alert comes when you are in reverse gear in some car is crossing behind you. But whatever a split view is. For my 2022 this CTASV is disabled in 706-01-02, however I know that the alarm feature exists. Maybe in your newer car you have something different.
Chapron
Detlef
germany
SAP Engineer
Ok 0700 0000 0016 disnt check out. I got a checksum error with 0016. however. 0700 0000 0017 checked out correctly. But i can not test it until I go on a autobahn.
jmgreen
Joerg
Germany
Mach-E 2022 RWD-ER
Please, let me know how it works for you. So far I haven’t found the courage to fiddle around with the many different ALC settings myself.
MVasco
Manuel
Spain
Mach-e 2023
Hi, great post! I own a 2024 MME (Europe) and I've been able to make some mods through Forscan, but there are some of them that I couldn't:
- Keyfob location: I've set 00C0 FFFC 3F74 in BCM 726-06-07. Doesn't work.
- High beam ramping: in my car, the HCM 734-01-04 value doesn't even exist.
- Pedestrian and backup sound: 720-09-02 X*XX XX -> my value is BF2D A1BF, not 4 or 5.
Those which work:
All chimes disabled
relock if door not opened
silence mode switch
cameras on when moving (although it only shows reverse camera)
GT Power meter
Double horn if cabin left.
Tilt mirrors in reverse
Just in case anyone can help with those that doesn't work or need help with the others.
