[Guide] Better Jump Point Access (Battery Access)
williswong
Willis
Los Angeles
Ford Mach E Red
Am I not printing this right? I can’t seem to get the negative/positive holes aligned to drill them correctly. I’m slightly off
when I print it out, I put it at custom scale 100%. Not sure if the margins on/off
Make a difference but this is what I’m getting for mine
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) ADC21F6B-D8DD-4CEF-9DA6-74A1B3ED2FF4
DevSecOps
DevSecOps
Todd
CISO
To be quite honest, the template creator made this template so it's not center over the battery posts anyway. I would align one, drill, align the other, then drill it.
Since they're not centered anyway if it's a 1/4 inch off it won't make much of a difference.
<SNIP>
I think I will put a 45A Powerpole connector under the headlight adjuster cover on my car for charging and flashing use.
I was going to put a Piper jump receptacle on my car then I found this:
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) IMG_2944
Unfortunately, today I dropped the red vinyl cover into the hole for the window washer neck. It's probably not necessary since it has the big plastic cover, but I'm trying to see if I can buy another one. LOL. ??
williswong
Willis
Los Angeles
Ford Mach E Red
Thanks for the help! Slightly off with the positive terminal, but still worked out just fine.
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) 7CEAD79B-EE61-4275-9EA9-F41CD016B7F6
DevSecOps
DevSecOps
Todd
CISO
Would folks be interested in 3d printed plug covers with the + and - embossed in them? Should be straightforward to model and make.
I'll answer from my point of view ... I wouldn't, but I can't speak for everyone. It's really not something that I want to draw attention to, so the stock plugs work well. For those that saved the + and - there's really no need to and if it's directly centered the - is still there, it's just the + that gets removed.
Other people can chime in, but that's my vote.
Sounds like a great idea.
Chuck
Chuck
SoCal
Mustang Mach E 2021
I would. If you design one would you be willing to share the STL file?
Abcdang
Alexis
Bay Area
Mach-E, Forester XT
I’ll work some prototypes later this week and see if they will work. Happy to share stl
Norm in NC
Norman
North Carolina
2021 Ford Mach-E
Very slick. What is it?
Illinibird
Frankfort Illinois
Mine too with the positive terminal but access is still fine.
Illinibird
Frankfort Illinois
Thanks for the shout-out, but it wasn't originally my idea. I saw it elsewhere on the forum. FWIW, I did not remove any of the plastic shrouding. I just lined up the holes by sight based on other people's pictures and used a two-inch hole saw. Easy-peasy.
I eyeballed mine too without removing plastic shrouding. Negative was directly over connection point and positive was slightly off but will work fine.
Abcdang
Alexis
Bay Area
Mach-E, Forester XT
can someone try a test fit? it's sized for a 50mm (2") hole.
there's a small retention lip that should help snap it into place
