[Guide] Better Jump Point Access (Battery Access)
21st Century Pony
Martin
Arlington, Virginia
Ford should make a whole new panel but this time with an access door. Or could you cut out a square and make your own access panel? Should be able to proxy a panel to it. Both are plastic so glue should be able to hold it.
See member HuntingPudel's battery jump points access panel mod in the DIY section.
alangant
Alan
Plano, TX
MME GTPE Rapid Red (ordered 10/22/21)
Seen that but he ran wires. I rather just be able to open small door or panel. That way can see everything and easy to connect jumper cables.
For anyone who just wants easy access to the battery jump points via holes, you can find info at
https://www.macheforum.com/site/thr...point-access-battery-access.10976/post-290201
The hole covers are at The Hillman Group 58179 2-1/2-Inch Hole Nylon Knock Out Seal, Black, 2-Pack - - Amazon.com
and template for the cutouts are below.
Billyk24
William
PA
Another option is to run a trickle cable out the front funk and trickle charge the 12V battery as desired.
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) 20230827_154034
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) 20230827_154201
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) 20230827_154418
DevSecOps
DevSecOps
Todd
CISO
Why would you do this?
Unless you have an extremely outdated job 1, the vehicle will maintain the LVB via the DC/DC inverter. Technology has advanced, we aren't in the 1960s anymore.
Billyk24
William
PA
I believe putting a trickle charger on it actually prevents it from sleeping. I could be incorrect about that but I remember seeing something about it.
What is an extremely out dated job 1?
Billyk24
William
PA
Better option than using 8 batteries at the pop out piece. Able to charge the 12v without using the hvb as in if one isnt driving the vrhicle for a time frame. Too many reports of low and dead 12v batteries.
DevSecOps
DevSecOps
Todd
CISO
There was a bug on the first release vehicles that prevented them from maintaining the LVB. It was software patched in January of 2021, I think.
DevSecOps
DevSecOps
Todd
CISO
If your LVB dies then you have much larger issues because the vehicle isn't performing as it should. I would rather know of an issue while it's at home vs on a road trip.
The only reason to attach an external charger would be if you are doing your own FDRS updates which hit the 12v pretty hard.
under 'normal' conditions, you literally should NEVER have to apply an external charger. If you really want to top up the 12v, just turn the MME 'on', disable 'auto-off', shut all the doors and leave it on overnight. That will hold system voltage at 14.4-14.9v and the LV will be 100% in the morning.
I think that 1-7/8" holes over LV connectors are advisable not only for charging, but also in case you need to GIVE a charge to another motorist. I wanted to be able to connect full size jumper cables to handle 100amps for that task.... AND because I wanted to be able to export up to 1500 watts of power to external inverter for 120v AC.
and while you are at it, I would HIGHLY recommend a third hole, over the HV disconnect that is between the 12v + and - holes. This is for the benefit of Emergency Responders, or dealership service procedures that require disconnecting HV before service.
What I haven't gotten to yet is digging in there and making access to the charge port 'manual release' handle reachable.
Earlofsandwich
Nick
Canada
Mach E Select AWD
I have used de-sulfating low current battery chargers for years (lately NOCO brand) to maintain/restore old batteries. One day, my MME LVB will be an old battery. I also connect up the battery charger for a day or two once a year or so to extend its life, and I do that on all my cars. Since I started that practice about 5 years ago, I have not had to replace a 12V battery. Also, I note that my MME uses 12V power every time I walk past it with my phone. Lights come on, relays click, etc. Some days I walk by a dozen times without ever opening up the car or starting it. Since the software fix (mine was one of the first in my area - coming up on a year old - and the battery went dead once), I have reasonable confidence that the 12V will be kept charged by the car itself, but that still does not give it the de-sulfate experience. I connected a cord from my battery maintainer to the MME battery, ran the connector up through the windshield washer fluid bottle neck hole. When gone for a long trip (we use our Highlander Hybrid as our vacation car), I leave the charger plugged into the connector under the MME hood. I don't expect to need to "jump start" my MME any longer, but battery maintenance is good for the battery and easy now with the connector accessible. No holes.
what type of noco charger are you useing? i really like this idea? and what type of adapter did you use? the M6 or 10?
.... I also connect up the battery charger for a day or two once a year or so to extend its life, and I do that on all my cars. Since I started that practice about 5 years ago, I have not had to replace a 12V battery.
yes, good practice to bring batteries up to 100% and hold for a few hours at 'float' voltage. Sealed batteries, you hold at a slightly lower voltage since they cannot 'vent' when equalizing the way the old flooded-lead batteries can.
I would like to suggest that this 'equalization'/de-sulfating charge can be done with NO equipment or charger with our MME's simply by leaving the vehicle 'ON' overnight, with headlights turned off, and auto-off disabled.
I also suggest that 3 holes, or an access panel, is a smart thing to add over the connection points and the HV disconnect for ease of service, possible 'quick charging', possible export of 12v energy, and safety for tow truck drivers / emergency responders in case of a crash where HV should be disconnected to prevent possible shorts and fires.
Also, I note that my MME uses 12V power every time I walk past it with my phone. Lights come on, relays click, etc. Some days I walk by a dozen times without ever opening up the car or starting it. ...
yes, best solution for this that I have found is to turn off BlueTooth on your phone. This basically disables PAAK and you car won't 'see' you walking by.
engnrng
Bruce
SoCal
NOCO GENIUS5, 5A Smart Car Battery Charger, 6V and 12V Automotive Charger, Battery Maintainer, Trickle Charger, Float Charger and Desulfator
NOCO GC009 X-Connect SAE Adapter Accessory Genius Smart Battery Chargers
Earlofsandwich
Nick
Canada
Mach E Select AWD
awe some thanks what do you connect to the battery terminals?
engnrng
Bruce
SoCal
The clamps that came with the charger. Then I reinstalled the plastic pieces so no one can touch the clamps by accident. I put the connector up next to the WW fluid fill for access, as shown in my photo.
