Harvest Program 23H06 - Battery Module Replacement
MacherAWD
North Shore MA
Healthcare Software
I think the answer is "it depends". It looks like it could be replacing all of the modules:
NOTE: For extended-range batteries, the fifth row may need to be removed if all of the affected SN are not found within the visible 5 rows and inspection of the fifth lower is needed. Follow the WSM procedures in Section 414-03A.
I'd be happier to have Ford give me a brand new pack than have a tech pulling and replacing modules.
I had yet to see companies relacing modules, just replacing whole packs. Its why I was curious if that can be done on the Mach-e, I had read and assumed it could, but will be nice to see it in practice.
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
They can take any part of my car they want. In fact, they can void my Options lease at any time and harvest whatever they want from it.
Hit me up, Ford.
Ford has been replacing modules on Lightnings for months.
hybrid2bev
2026 Rally
I think this means that in order to inspect (see the stickers) the 5th row lower modules they may need to temporarily remove the 5th row upper modules that are only present on extended range batteries.
Ford Mustang Mach-E Harvest Program 23H06 - Battery Module Replacement 1705598516404
True but language elsewhere uses that language like “all of the affected SN“. My point is if you are “lucky” enough to have 6 matching SNs, you might win the battery lottery and get all 6 replaced. You may know until after they dig in, though.
hybrid2bev
2026 Rally
Better go and get some PowerBall tickets if that happens. ?
I agree with you it's possible, but not probable.
VindictivePantz
Arlen, TX
2021 Mustang MACH-E Premium AWD w/ Ext. Battery
  • Glass half-empty: They're concerned about something and trying to learn more and get ahead of it
  • Glass half-full: They're trying to make things better long-term through real-world sampling and research
Either way, it's a positive, but an invasive one. It'll be interesting to see the customer letter once someone receives it.
VindictivePantz
Arlen, TX
The specificity of dates is interesting - I doubt there's a different in batteries between November 11th, 2021, and January 4th, 2022, especially given demand for the MME back in the day.
Assuming it's just to bracket sample sets, but a gap of ~2 months of "research" scope is interesting.
Ford Mustang Mach-E Harvest Program 23H06 - Battery Module Replacement 1705602663994
I think those gaps were the months production was shut down.
Neil4Real
Interesting as my build date is just outside this window at November 28, 2021.
JamesStew71
James
Jordan Ford
mustang mach e
auto tech
Wonder if they swap the whole pack, or just pull a few modules and replace those. Although I havent heard of that happening, or if it is possible.
Ask me , Since most of us early owners “are in the recall “ the whole pack would make more sense 22 mach rwd std
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
Maybe, but why bother explaining and illustrating the distinction between modules and arrays if you’re just gonna swap the whole thing? It seems to me that they’re singling out some specific subset of modules for testing purposes.
As to not wanting them to mess with stuff, based on my HVBJB recall progress, I’m with you on that.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
interisting, thanks for posting
