CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
Grizzl-e off in the distance with the cable running along the ceiling...
Ford Mustang Mach-E How Do You Roll (your charging cable)? 20230123_135653
emersonsdad
Pablo
Cali
22 MME CA R1
Ford Mustang Mach-E How Do You Roll (your charging cable)? 19FEBE86-C2E6-416D-BEB4-E386F693856B
Mine is boring!
NW Suburbs of Chicago
2021 Mach-E Premium AWD ER, Star White
IT Support
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_7461
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_7462
My version of "Pull and Slide".
Keeps the cables off the floor and relatively clean.
woody
CO
Clipper Creek. It has a lip and we loop (larger loops than shown by most in this post) the cord around it. It came with a plug holder which we plug into when not charging.
We have a movable cabinet protecting the cord and EVSE.
Ford Mustang Mach-E How Do You Roll (your charging cable)? 20210506_172005
3 car garage. Two spaces (stack: front to rear) to right of EVSE, one space to left. EVSE can reach three EVs, as long as one is the size of a Bolt.
Jax_GT
AZ
2022 Mach-E GT (Build in progress)
Inspired by other peoples' setups.
I’m jealous of your tall ceilings, but it does make your garage door opener look like a spider!
ponEpwr
Nathan
Kansas
GTPE, F-150
A little bit of a pain dragging the cable around the front of the car. But it gives me the ability to charge in the driveway or garage. Plus I only charge once a week for the most part.
Ford Mustang Mach-E How Do You Roll (your charging cable)? 20230128_081113
Jonno21
Derby, UK
You have an oven in there as well for snacks. :)?????????????? Whoops, got carried away. The Mach E won't fit in most UK garages as the car is too wide/entrance too narrow.?
woody
CO
And.... to the left of the "oven" is the Level1 supply cord. Both (Level1 & Level2) supply can easily reach all three (EV) parking spots.
The "oven", as well as the crock pots (shelf above), are stored there - use them in kitchen. Even have a really old tech. (70 years) deep fryer (for pommes frites) and a George Foreman grill out there (out of picture). Even my outside grill is electric.
Ubiquitous electricity.
Use No fossil fuel/carbon emitting sources for energy. Just that little star shining up there (with a little help from my solar panels).
Even had the syndicate remove their natural gas lines from my property. Had to pay the bastards to do it. But what to do when they have that many guns pointed at you?
Do they waive the toll on the M6 for the MME when you venture to the big city? Does it save (enough) time anyhow?
Jonno21
Derby, UK
Still have to pay.
I do try NOT to venture to Birmingham if I can help it. One way system is a nightmare plus most of the road markings are rubbed off so in the wet at night you can't see which lane you're supposed to be in and of course no one will let you in to change lanes so you end going in a different direction to that intended. The sat nav can't keep up with the necessary lane changes.
There is the A5 and A452 which run along side the M6 toll so I use those if I happen to be in the area. I don't know if it saves time but it saves anxiety not using the toll.
21st Century Pony
Martin
Arlington, Virginia
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
I mounted my charger in my carport, and looked for a slim cabinet to protect it. I ended up getting a cabinet for a Tesla charger and modifying it. The charger was between two fascia boards and I wanted the cabinet to stick out minimally from the wall. Also, my holstered ChargePoint charger sticks out a bit. So I decided to remove most of the back and install it over the top.
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0632
Removed the door and temperature gauge.
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0636
Removed the internal brackets with an oscillating saw, etc
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0637
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0635
I measured my opening on the back and used a utility knife for a few hours to score it as heavily as possible.
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0640
Drilled a hole near one side and used the oscillating saw to remove material. I created tabs of metal which I could then break at the score lines.
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0643
I removed the remaining metal, bending the tabs back and forth at the score lines. Unfortunately, the back bottom and top edge were merely edge spot welded and shook loose. So I epoxied those and painted.
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0645
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0647
I put rubber edging over the newly cut metal and mounted it with some wood inserts and bolts. The bottom slugs also loosened so I siliconed those. I added a velcro cinch to fully retract the holster, otherwise the handle trigger gets pushed in by the door (it's that tight).
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0654
We have wasps, so I put some screen and a plug at the bottom. I also added small filler boards between the fascia boards top and bottom.
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0658
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0656
Ford Mustang Mach-E How Do You Roll (your charging cable)? IMG_0649
SinaiKD
Dwain
Rockwall, Tx
2022 Mach E GT
Over & Down
From the west wall over the top and down the center since I back into my side. I use a ChargePointe (direct wire 60 amp) so I can have the Ford Charger in the boot with my Modern Spare when on road trips.
Ford Mustang Mach-E How Do You Roll (your charging cable)? 02B95A27-1FD5-4ADE-94F0-1660990E5388
Rt1AWD
CA
MME CARt1 AWD
I have no charger at home
Unclespike102
Green Bay
Mach E Premium
You’re spot on - why didn’t I attached the strain relief. Probably cause, I’m blonde, balding and grey?
