Jamers99
Jason
Tampa, FL
2023 Mustang Mach E GT
For the record, I removed the frunk panels so I could use my multi-meter to test the battery voltage directly. I got 12.8v although I have not idea if that is normal. My Focus ST battery tested at 13.1v. The reason I am concerned is I have a dashcam that is hard wired and uses power during parking-mode so I want to keep an eye on 12v battery levels. Already had my first low-battery warning just days after installing the dash cam. Not sure what voltage the battery has to drop to in order to trigger a low-battery warning. I adjusted the dashcam parking-mode settings to only stay on for a couple hours now so that should mitigate 12v power consumption.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
Yes, that is where I obtained the screen shot however I do now see where the 12v battery level is shown.
You need to do one more step and click on your account page.
Ford Mustang Mach-E How To Get Failed OTAs To Install Screen Shot 1
Ford Mustang Mach-E How To Get Failed OTAs To Install Screen shot 2
Please see this about dashcams and the 12V battery: https://www.macheforum.com/site/threads/12v-battery-faq.32744/
OK, that works. Wow, it's nuts that it is not on the initial site landing page. You have to hunt for it.
Also be advised that % doesn’t update when the car is off, so you won’t be able to track 12V drains. Unless you do a manual FordPass refresh to update the value.
Jano55
Jean
Canada
Mustang mach e
Public
Can someone check my 12v health ? My vin is 3FMTK3SU2NMA07329
Thanks
Thanks
Your vehicle is way behind on updates and they've failing because of configuration issues. They replaced your GWM last year so that might have something to do with it. I'd recommend scheduling a visit to get the software updates done manually.
Dhelmet78
Charles
2021 mustang mache
I haven’t been able to update since November or December. It’s saying update not completed. I called Ford and the guy on the phone told me the car tried 3 times then gave up months ago with some kind of manifest error, I don’t remember exactly what he said. However he didn’t mention the battery at all. I checked the dashboard today at it said 62%. So I went for a long drive and did some errands. Every time I stopped I left it running so it was a few hours. I got it up to 78% and it hasn’t moved since then. Can someone check my VIN and see what’s going on? My local dealer didn’t know. I’ll gladly message the vin but I don’t want to post it here.
it suggested to me to do a ford connect reset so I did that a few weeks ago but nothing has changed.
Motomax
Max
VW GLI, 4Runner
24-PU0102-CHG-SUFX update has been failing for weeks. My 12v battery seems to be stuck between 60-72% even though I have a 45 min commute and charge from 50-85 almost every night. My Noco 3.5amp charger had zero effect (might try a higher amp one). Also Turned off parking mode on my dash cam but still no improvement. I’ll try to remember to get a voltage reading after work.
you think my battery is just shot?
Message me your VIN.
Added procedure to fix BMS data quality flag preventing OTA installs. This is a rare situation I will indicate to you when I see it.
Brian-e
Mach-E X Premium
Ours has been attempting to update for what seems like months. We finally took ours to Ford to take care of and they wanted $250 since it's out of warranty. Wouldn't help us with the update.
rolltide
Atlanta
2022 Premium RWD SR Grabber Blue
I just followed the "Blower Charge" Method for three hours in my 2022 MME but it only increased the 12V battery from 66% to 71%. I don't have a dash cam or anything else plugged in.
Is my 12V battery unhealthy?
Ford Mustang Mach-E How To Get Failed OTAs To Install Screenshot 2024-06-30 at 3.44.52 PM
