Macheeee
Stu
2016 F-150, 2013 Honda Crosstour, 2010 Audi A5 Con
Self employed
We got stuck at the car wash... before you cringe, it was touchless. Save these instructions! We had to do a web search to find out how to really engage neutral with the brakes released so the wheels rolled freely:
Entering Temporary Neutral Mode
1. Power your vehicle on.
2. Bring your vehicle to a complete stop.
3. Press and hold the brake pedal.
4. Shift into neutral (N). Note: An instructional message appears.
5. Press the low (L) button. Note: A confirmation message appears when your vehicle enters the mode.
6. Release the brake pedal. Note: Your vehicle is free to roll.
7. Switch your vehicle off.
i would not turn the car off. There is a message on screen to press the break pedal to be able to switch out of neutral.
Only 5 annoyed customers behind us.
wmaney
Wade
Mach-e GTPE, daughter drives Ford Focus Titanium
Thanks for this . When you say at the end,” I would not turn the car off,” do you mean contrary to the instructions, you left the car on? We’re you worried that it would not start? So when you came to the end of the car wash, did you just press the brake pedal and rotate the dial to D and drive out?
Must have been a bit nerve-racking with those other customers behind you - sorry about that. I assume the Mach e came through unscathed?
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Yeah BTDT*
This really only applies if you have auto-hold turned on as it holds the brakes when you take your foot off the brake. With auto-hold turned off you can simply switch to neutral and let it go.
Last time I was at the car wash I was tempted to turn off auto-hold and leave it in 1-P to see if it would regen through like my Bolt did.
*Been there done that.
It's also on page 174 of the manual (search for "car wash"):
Ford Mustang Mach-E How to place Mach-E into neutral 1618231189727
Not necessarily. A lot of modern cars (including the MME) have a safety feature that automatically shifts the car into Park when you exit the vehicle. It's meant to prevent it from rolling away if you put it in Neutral by accident. That's why they give you a way to tell the car that you really meant to leave it in Neutral.
GoGoGadgetMachE
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
I tested at home with the wife in the car. No matter what mode we were in (OPD, autohold) if she put it in Neutral and stayed in the car, I could push it, easily. If she were getting out of the car, she had to push “L” first or it shifted to Park. . Never thought of turning it off.
JamieGeek
Was speaking for car washes where you sit in the car.
Macheeee
Stu
Self employed
All great comments and feedback. Our experience live at the car wash while sitting in the car, it would not budge. A true Mustang. Would not let us saddle it either ?. I didn’t turn it off because I wanted to be able press the brake and switch to drive rapidly for fear of stopping for too long, starting the car and drive off while the car behind in the wash was approaching. I would love to hear from someone else who has gone through a car wash and the steps that they took, and was auto hold on or off.
breeves002
St. Louis, MO
2021 Mach-E GT PE
If you put it in neutral while you're still rolling slightly before auto hold has kicked in it solves this issue too. I went through this in my 2020 escape. All I did was not stop completely when I put it into neutral.
Macheeee
Stu
Self employed
JamieGeek
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
After my home tests, my wife and I have been through the automatic wash 5 times. Each time just set the car in neutral and stayed off the brake. Each time the car was in one pedal drive and, in my car autohold was off, in her car autohold was on. Each time was car was left turned on. Never has the car refused to roll.
Macheeee
Stu
Self employed
So odd. the random responses of our different cars is perplexing. I intentionally turned off opd before we arrived at the station. We even turned off the car. Turned it back on, rolled a little bit then put in neutral, and the back wheels were locked. Front wheels rolled. Do you have AWD?
Reactions: UW2
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
We do. Both our cars are AWD ER’s.
