How to - remove front license plate bracket
eltonlin
NorCal
FE Gray
After searching, apparently simply taking a smaller drill bit and drilling into the pin @ the center of the rivet works as well.
But what you did instead was soften the rivet with heat gun and push in the pin?
JosephG53
Novato, CA
Mustang Mach-E First Edition Grabber Blue AWD Extended Range
Exactly....some people might be able to just push it out with out heat. Seemed a less risky way than drilling for me.
eltonlin
NorCal
FE Gray
Well, I don't have a heat gun, but I do have a drill. So using a 1/8" drill but, I drilled into the center of the rivet so as to push in the pin. Was rather easy, though you do lose the pins behind the bumper. Used a trim tool to pull out the rivets. All in all a pretty easy removal - 5 min or so.
Will plug with some bumper plugs I ordered (supposed to get them today).
Now time to install Craigs bracket...
Ford Mustang Mach-E How to - remove front license plate bracket IMG_1471
Ford Mustang Mach-E How to - remove front license plate bracket IMG_1523
Ford Mustang Mach-E How to - remove front license plate bracket IMG_1524
Ford Mustang Mach-E How to - remove front license plate bracket IMG_1525
JWW
SE Michigan
83 Mustang GLX, 21 Mach-e FE, 22 Lighting Lariat
Accountant
I would take a look at your window sticker.
I agree, when I ordered mine I told the salesman I did not want the front license plate bracket. He deleted the no charge item and commented that if it isn't in the car it won't be installed by his guys. Mine arrived with a clean front end. Now we know it is a factory installed item so if you don't want it; tell your dealer to delete it from the order.
methorian
Roanoke, VA
IT Admin
Also drilled out my license plate. Didn't think about it before it went to the PPF shop, but my partner was able to run back over there with a drill and quickly got it off so they could put the PPF behind it.
Gotta go get some christmas tree clips to put the bracket back on though. None of the license plate bracket clips I have are small enough to fit the pre-drilled holes.
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2023 MME
Since Michigan doesn't require fronts they aren't getting installed at the factory. Wish my dealer would have been proactive enough to delete them (they also expected it to be a dealer installed item), but there has been some chatter that the system is reapplying the bracket before the sticker is generated, even if the dealer deletes the item from the order. We are still waiting to see if the delete option even works for states like Ca.
I have not seen this happen with previous orders from Ford or other manufacturers. Extra "special" feature for the MME assembly.
https://www.macheforum.com/site/threads/front-license-plate-bracket-delete-does-it-work.3413/
VegStang
Leo
Silicon Valley
Garbone
Gary
Loafer
I removed mine.
Step one- wedge 4 fingers behind right side of bracket .
Step two- yank the thing off shattering said plastic rivets.
Step three- place three new plastic rivets to fill holes.
MTNestr
Paul
NW Ohio
2021 Grabber Blue FE MME - traded for - 2025 Velocity Blue Mach-E GT
Are the rivets plastic? After they are heated do you punch in the middle?
eltonlin
NorCal
FE Gray
I removed mine.
You HULK!
Ford Mustang Mach-E How to - remove front license plate bracket tenor
JWW
SE Michigan
Accountant
So when is your new GT front end supposed to arrive?
ngerakines
Nick
Dayton, Ohio
2021 Mach-E
Followed the instructions here. Will admit that using the drill on it gave me a little anxiety, but made the process a lot easier. I ordered 2x packs of bumperplugs (2 each) and I think it color matches just fine.
Ford Mustang Mach-E How to - remove front license plate bracket 63726894539__44F8BF71-295A-4DA4-9274-1E8825D01D6B.JPEG
Ford Mustang Mach-E How to - remove front license plate bracket IMG_0120.JPEG
eltonlin
NorCal
FE Gray
If anyone is looking for a single Carbonized Grey bumper plug, feel free to DM me. Definitely can save you $$$ from having to order a whole second pack.. (thanks Ford!)
