takes about ten minutes....
using a pair of stubby 'regular' screwdrivers and pliers, or an 'auto-fastener' tool to minimize damage to the (fairly soft plastic) fasteners.
You can re-install the fasteners, or get some new ones at a hardware store, to plug the holes. Or leave the extra drain holes and put some foam or Astroturf (my favorite) in the bottom of the frunk to keep cargo from sliding around and clunking when you are out there Drifting.... ;)
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup 20210228_0 separators in
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup 20210228_1 tool
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup 20210228_2 usingTool
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup 20210228_3 don
dliunatic
Dallas, Texas
Have you noticed any additional road noise or issues after removing it?
Jayally
Michelle
Ontario, California
2015 Mazda CX5 GT, 2019 Dodge Challenger SXTplus
Field Manager
How easy is it just to remove the center piece so I have more space in the middle?
The Electric Duo
Patrick
Oceanside, CA
machevlog.com
Woeo
Woeo
Fusion Energi
It's all one piece.
Others (another?) have reported it is possible to remove the center/cross divider by removing all three, sliding the center out, then replacing the two sides. It is true that the center/cross divider can't be slid up with the side pieces in place.
Ten minutes with a Dremel tool or an x-acto blade cutting away the stop at the top might save 20 minutes removing and reinstalling the pins.
BillK
Lucid Air GT, Zero SR/F
Retired-ish
I heard somewhere on YouTube that this useless divider was added because of some US regulation and apparently other countries won't be getting it. Does anyone here know whether this is true and if so what regulation? The frunk does have the emergency escape button so it does seem that Ford's initial intent was to not have this divider.
Papa T
Treven
Birmingham, AL
BMW X1
For what it's worth, here is this guy's opinion. He turns what could have been a 1 minute video, into a 3 minute one, but other than that, seems to be fairly useful information.
Those Evil Panel Trim Clips-- Best Tools to Remove Them - YouTube
The Dent Fix tool he recommends is a little pricier at $20+, but it does look like he likes a version of one of the tools that Mach-E VLOG has linked to above. (BTW, how do you appropriately mention another user, so that they are linked and noticed?)
Marcel
The Netherlands
Woodworker
@Papa T will do the trick
JSW
Ann Arbor
Chevy Bolt; Porsche Boxster; Chevy Blazer; Jeep Wrangler
I removed the divider, and ruined a couple of the attachment devices. i tried to be super careful, but without that tool, the screwdriver method permanently deformed a couple of the attachments.
The frunk is way more usable now.
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup 4074ACA2-B29D-4A40-8D68-E5CCBC49DFD8
