- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Thanks, if was parked unplugged at the airport at 80% and the 12V battery was new it should't have gone dead being parked for a week. Likely software glitch, hopefully you can somehow get some updates done so that doesn't happen again.Don't know exactly what it was when I parked it, but it was 80% when I returned (and it had charged to 90% overnight before leaving for the airport - 24 miles away, so I'd say it was 80-81% when I parked it)
No, because a battery charger cable is too small and doesn't support enough amps to jump start a dead battery. You will not be able to charge the battery from dead because the inrush of the car trying to wake up is greater than what the battery charger can provide. Others have added the cable for battery maintenance, but it won't help once the battery has gone dead.Is there any reason we couldn’t just install a cable like this directly to the battery, and perhaps route it to somewhere externally where it could be accessed if need be (behind front bumper, etc)? I haven’t had anything apart, so no idea how tight everything is in there. But this would sure make access a whole lot easier, and prevent the need to cut holes in panels or have to open the frunk to get going again. In the event the 12v is dead, I’m wondering if we couldn’t just connect that to one of the recommended jump start units (via a DIY adapter cable made from the CTEK extension cable)?
You have to use the front bumper leads to open the frunk if the 12V goes dead. End of story.
