Darkenmage
Manny
Texas
Mach E GT AWDe and Honda Insight
Semi Retired
I decided to venture and do this without any help or wiring diagrams. I couldn't find ANY resources online for any reference. I managed to figure it out and I took photos along the way to help others that may be wanting to do the same.
I've done many mirror taps in the past, but this one was a bit intimidating, not knowing where to tap because of all the unusually color coded wires, and all the tech involved in this piece.
PLEASE PLEASE be VERY careful removing the plastic housing. I don't want to be responsible for anyone breaking this piece. Be gentle and take your time.
Circled is the terminal that you will be using removing and tapping into. The release is on the top, towards the windshield.
Testing the taps:
The Black Wire is the neutral/ground. Connect the Black tap wire to this. The White Wire is the 12v switched lead. Connect the Red tap wire to this.
This is what it looks like tapped:
Testing:
Vehicle off:
Vehicle on:
Complete!
Exactly where in the cover should one start to pry it to open? I do not want to pry in the wrong spot and break any of the clips?!
Darkenmage
Manny
Texas
Semi Retired
Testing the taps:
Testing:
Vehicle off:
Vehicle on:
Complete!
Sorry but I tried pulling down on the middle left and right side of the cover but it wont budge and I did not want to exert too much effort in fear of breaking the tabs. Are there specific spots on the cover where you need to do the pulling/pinching to release those tabs?
Can one use something to gently pry them open?
Darkenmage
Manny
Texas
Semi Retired
You can just use your hands.
Wow, watching your video, it seems to have pried so easily but when I tried mine, it is really super tight and I am afraid to exert additional pressure for fear of breaking any of the tabs holding it.
Any suggestions?
Darkenmage
Manny
Texas
Semi Retired
TY. I will try again and exert more effort. Crossing my fingers and toes....
Darkenmage
Manny
Texas
Semi Retired
Panzer948
Charlotte, N.C.
2023 MME GT PE, 2021 Ford Bronco, 2015 BMW M4, CJ5
Geologist
Great write-up as I need to install 12V power on for my radar detector and eventually a dash cam. I wonder if this circuit could handle both? Has anyone split the + and - leads coming out of the plug to go to dash cam and detector (or some similar 12v device)?
I would think that one additional accessory is already pushing the circuit, as it was designed just for the mirror dimming. I definitely would not try to add two accessories to the circuit. It is not all that hard to run power up the A-pillar from the fuse box. 🤔🐩
Panzer948
Charlotte, N.C.
Geologist
True, but alot easier to pull from there and a time savor at that. I don't have a problem going down the A-pillar if I need to though but need to get more familiar with this car (had it only a few days) so just trying to learn. Maybe there is another circuit in there I can tap into. If not, A pillar it is. I will likely need a separate constant on power source anyway.
If you need both switched and constant, check over on the FitcamX thread. @markboris and several other of us ran +12V switched and +12V constant up the A-pillar for our cams (along with ground). 😊🐩
RC-Premium23
Richard
MyMach3!!
2023 Mach E Premium
Testing the taps:
Testing:
Vehicle off:
Vehicle on:
Complete!
What kind of pins are you using to tap that connector?
Thanks!
apailthorp
Aaron
Seattle, WA
2022 Mach-e GT, 2016 Porsche Cayman
Vinces34
Vince
Nevada
2022 mache
THANKS jdmrc93! Took about 10 mins and works perfectly In conjunction with the irr mount for the redline 360c.
