murphy62
- John
- Apr 2, 2021
- Horsham, PA
- 2016 Tesla S90D, 2021 Mach-E AWD ER
- retired
This procedure will block the open end of the structure that allows the clip to slide out.
Get some small diameter steel wire or failing that a supply of paper clips which are usually made from steel wire.
Select a drill bit that has a diameter slightly larger than the wire.
Look at the open end of the structure that holds the clip.
Note that there are two raised ridges on either side of the clip.
Drill a hole just past the end of each ridge.
Bend a piece of wire so it will go through both holes.
Cut the excess wire from the bent parts about 1/4" from the bend.
Insert the wire into the holes and bend the ends back toward each other.
This creates a block that prevents the clip from sliding out of the structure.
Repeat until all of the clips are blocked.
It's best to do this before any clips are lost. Four were missing when I modified my car.
I was not able to find the clips on Amazon. I did find one that required modification before it could be used.
