bigredx86
Pittsburgh, PA
2023 Ford Mach-E Premium STD AWD
I don't think 20 miles is that bad. If you drive at 120mph(!) from the start of preconditioning all the way to the station, that's a solid 10 minutes of heating. Unless you're starting from single-digit weather (where driving @ 120mph would be ill-advised), that's a good amount of time to warm up the pack by 10-15 degrees. Realistically, it'd be about 15-20 minutes between the start of preconditioning until you're plugged in, so that's even better. It won't get the pack up to 80+ degrees, but then it's a balance between faster charge acceptance and burning through more energy that you'd have to put back into the pack anyway.
I think 20 miles makes sense as I believe thats about what Tesla does with theirs, or at least it seemed like it when I had one. Basically, any miles within 'X' radius it'd start preconditioning. If you were like a 100+ miles it wouldn't do anything right away.
Teslas have a much bigger battery heater though. Theirs will output 4-7 kW en route, ours will only do about 2-3 kW while also using the cabin heat. Because our heater is 3x smaller we need to start 3x sooner than a Tesla to get a similar effect.
kltye
IB MME Premium RWD
I keep forgetting people actually use heat ?. I only set it to 60 only if it's single digits outside or if the windows start to fog ?. Pretty sure the MME heater is 6kW; to maintain 60 in the cabin, I believe it uses ~1kW, so I'm fine with it using just 5kW to heat the battery at worst.
At 26°F outside I’m averaging about 3 kW of heater power with a 68°F setting (see graph). The maximum heater output is 5-6 kW depending on return temperature. That’s how I got ~2.5 kW remaining for battery heating. I’d be shocked if you could maintain 60°F inside with only 1 kW in single digits.
Ford Mustang Mach-E Power-Up Software 4.1.3 pushed 30604BBA-0583-4F2D-B200-5E284395CCF3
kltye
IB MME Premium RWD
I guess I'll just have to take a winter vacation up north to test this out. For science!!
bigredx86
Pittsburgh, PA
Honestly, any preconditioning is better than zero. Hopefully there was some thought behind the 20mi radius. Like I said, I don’t remember what the Tesla range was, it may of been less because of the bigger heater. It was also summer as well so my observations could be skewed as well.
rcechinel
Atlanta
2022 Mach-E Premium ER AWD
Tech
I think we gotta get used to that being most people. I love this forum and I'll admit myself and everyone else on here is not normal ?
I'm normal, my mother had me tested. ?
rcechinel
Atlanta
Tech
Isn't the MME heater just like 5.5kw? In the announcement wasn't it mentioned "if there's unused capacity in the heater" or something like that?
Chapschaps
Oneil
CT
Mach E select Fusion energi
Gotta make sure you aren’t using wireless CarPlay, because that uses the Wi-Fi connection. Go to phone settings on the car and turn off wireless projection. It’s not a Ford issue it’s just how wireless CarPlay works.
I did all that still would not connect
kdonnel
Metro Atlanta
2022 CA Route 1, 2020 Bolt EV
I see it actually making the YouTube feature much more valuable.
I am one of the people who can't seem to get his MME to connect to the iPhone hotspot.
The first time I was in a position where watching videos on the SYNC screen would have been a good time killer, the only wifi available required interacting with a captive portal. So I just killed time on my phone, a much smaller screen.
I thought the lack of captive portal support was intentional to try and force people to pay the $10 a month for Ford streaming. As a result it is surprising to me that captive portal support has been added.
