- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
OK, I'm going to give you some things to try if you'd rather fix it yourself.Just an update- At the moment all of my issues are still unresolved. Blue Cruise hasn't yet turned on. My friend just took delivery of a 2023 Premium as well and is experiencing similar issues.
I'm going to have to take my car into the dealership to get it resolved.
First pull fuses #11 (TCU) and #21 (GWM) under the glove box for 5+ minutes (set a timer). Reinstall and drive the car for a few minutes. Then check the BlueCruise maps expiration date (should say 13-04-2023) and TCU status in Bezel diagnostics (should say provisioned).
If that doesn't work, then follow this:
2023 Model Year vehicles with BlueCruise should update the maps automatically. Ensure that the connectivity settings are enabled and that OTAs are enabled. If all settings are enabled, then ensure that the vehicle is authorized in FordPass. If it is not, then authorize the vehicle to the app, and then determine if the date updates. If it does not, then carry out 10 key cycles and check to see if the date updated. If the date did not change, then carry out a master reset on the SYNC system, authorize the vehicle in FordPass again, and then cycle the key 10 times.
Let me know what works and what doesn't to update the map expiration.
