Purchasing and Programming another FOB
santa fe,nm
www.envirokarma.org
Solar Sales/install
PAAK works on my current phone when I activate it (I have a few times before having an issue then deactivating it). It's just the backup phone that it doesn't like (yet). I already did a factory reset on it, so it has a totally new FordPass install on it.
I don't want to reset the car settings again though. It's not worth starting over there. I'll play with it a little more, but we have 2 fobs now so it's nothing important anyway.
I installed the Android FordPass update yesterday, so maybe that fixes a few things. I'll probably try activate PAAK on my real phone again first and see how that goes first.
I see, you DID get PAAK working on one phone at least, and are trying to add a second phone.
You definitely do NOT want to clear the Backup Start Code you were able to set with the first phone! You are just 'adding a phone' to be recognized as a Key by your MME. If the second phone doesn't get recognized, you can always use the 5-digit door code to get in, and then your BackupStartCode to run.
I have had some luck getting my phone to 'reconnect' and be recognized if I :
- turn off Bluetooth on the phone
- turn BT back on the phone when standing near MME
- open FordPass app on phone
- use FordPass app 'unlock' button to enter MME
- use FordPass app 'start' button to start MME
dbsb3233
TimCO
Colorado, USA
Actually, what I was trying to do was deactivate PAAK on the phone I really use, but still have a backup START code active. But when you deactivate PAAK on a phone, it also deactivates the backup START code associated with it. I tried that, hoping I could just do that. The START code worked an hour later, but it was gone when I tried it the next day. I assumed that the car was just slow to update after I deactivated PAAK on the phone.
The only reason I'm trying to activate PAAK on an old phone is to set a backup START code. Then I'll just turn that old phone off and put it away in a drawer. That way I'd have a backup START code and no bluetooth'd PAAK that might be causing other issues or conflicts with the fob.
santa fe,nm
www.envirokarma.org
Solar Sales/install
aha
I went the other way around, and put my Fob in the drawer at home.... Left PAAK on my phone, if it works, great, if it doesn't I just use the doorcode and console code.
machefan
NJ
Link no longer works, any ideas on a new link that will work? I get my car in mid June and want a second FOB
Ask once not twice please.
I will say it again, google the part number.
Ford Mustang Mach-E Purchasing and Programming another FOB tempImageJINXF4
Flowell
Forrest
Tennessee
mach-e
Civil Field Engineer
the reply to the second question was about as useful as the first. maybe the 3rd time will be helpful. When I google that part number, 77 results come up from all of the interwebs. 50 bucks to anyone who can find that part number on "the google" where I can buy it.
Looks like supply is drying up. How do you feel about refurbished? 4 left.
https://oemcarkeymall.com/products/2020-ford-mustang-smart-keyless-entry-remote-key-fob-trunk-4b-m3n-a2c931423-mustanglogo?currency=USD&variant=37821475881138&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=EAIaIQobChMI7OHp7-ru8AIV1Ap9Ch26jQFqEAQYAyABEgIcy_D_BwE
machefan
NJ
The post with links just given should help, however when they get posted they go quick. So I was trying to help with not posting a link. Good luck either way and welcome.
For others the part number is - JR3T-15K601-FA which fits a few Mustangs.
machefan
NJ
machefan
NJ
Most likely any FORD ~2020 315 MHZ PEPS FOB with the same button layout will work.
Just a guess here, others can confirm who might know better.
Ford Mustang Mach-E Purchasing and Programming another FOB Screen Shot 2021-05-29 at 9.29.52 AM
Ford Mustang Mach-E Purchasing and Programming another FOB Screen Shot 2021-05-29 at 9.29.32 AM
It's really the FCC ID that dictates whether it will work with the MME or not. If it has the right button layout and an FCC ID of M3N-A2C931423, it'll work. Ford uses a different FCC ID for fobs with a remote start button, so none of those will work. I tried it with a fob for an ICE Mustang with a remote start button and confirmed that it doesn't work with the MME.
Old Guy
Hilton Head Island
2021 Ford Mustang Mach-E EX, RW
I don't own an Mach E yet, drive a 2011 Explorer, but the discussion of the PAAK reminds me of the anger generated in 2011, and after, by the SNYC. It took three iterations, I believe, to get it right. Used to have to sit in a running car with a thumb drive inserted into something to get the latest updates downloaded into the car. Eventually they got it right.
