Rear Air Vent works???
JPT
Des Moines, Iowa
Audi Q5 and Caddie DTS
Mechanical Engineer
I had for the first time passengers in my 2023 MME GT and we noticed no matter what we did with the climate control you could not get air to come out of the rear seat air vents. There doesn't appear to be any control of it. Of course this happens when its only 15 degrees out! Anybody else know anything about this? Thanks
Ford Mustang Mach-E Rear Air Vent works??? 1701122474855
hybrid2bev
2026 Rally
Silly question…was the vent open? There’s a dial under the vent to open/close it.
AKgrampy
Fairbanks, Alaska
I just tested mine on my GT and air did come out for both heat and defrost selection with vent open.
My 2022 F350 would only output AC to the rear vents if the control was on auto. Is the MME similar?
Those rear vents are ducted the same as the front panel vents. So if there air coming out of the front panel vents, there is air coming out of the top rear vents. Mode selector has to be on panel, whether you set it there manually or the AUTO setting did, it doesn't matter.
DugthePug Dad
Pat
2023 Mach E premium
What do you guys mean by panel ?
William Shaw
William
Canada
2022 mach e gt performance 2018 wrx
One setting has to be on cabin if its on defrost or floor it wont come out the back
JPT
JPT
Des Moines, Iowa
Mechanical Engineer
Thanks for replies everyone. I did manage to rotate the damper open and closed but very little air movement. Unlike other cars it appears this rear seat set up has no individual fan control and relies on whatever the main cabin fan is doing. Bad design in my opinion for this high tech of a car. Oh well, can't do anything about it now. BTW cold driving as in 25 degrees and lower you lose 1/4 to 1/3+ the normal range. Bummer. A heat pump would have been much better!
OMG, heatpump...
RedStallion
Mach-E, et al
I noticed the same when the weather got cold and I needed to use the heater. The front an rear vents work fine when using AC, but nothing coming out of them when turning on the heat, even at max setting. I only see the heated air coming from the vents close to windshield.
Heat comes out of the lower console vents near the floor.
