Rear Hatch not closing
MomentoX
MomentoX
Jeff
Denver
Mustang Mach-e GT
Sales Director
Thanks. The problem seems to have gone away, at least for the moment. Not sure if this was the fix but here's what I did:
1. Removed my car from the Ford phone App
2. Deleted the App from my phone
3. Used my key fob from that point forward (no more phone as key)
4. The key fob by itself worked for the rear hatch, and the rear hatch buttons started working again
I currently only use the key fob, I gave up on the phone as key (never reinstalled it). The phone as key never really worked from the start, I would get locked out, car wouldn't start, etc.
MrRongoose
NJ, USA
2021 Mustang Mach E Premium AWD SR Red/Blk Onyx
My PAAK has been really reliable since last CSP. I tried what you tried and it worked for a while but the problem kept returning randomly. Eventually, everything I used to do to get it to work stopped. When the dealer tried to reflash the module, they said it was corrupted and bricked. Maybe those things we all try work for a while until the corruption it too much
MomentoX
MomentoX
Jeff
Denver
Mustang Mach-e GT
Sales Director
Hi there! Would you send us a private message with your VIN and dealership name and location? I'd like to look into this concern.
3FMTK4SE4MME00763
Larry H Miller Ford of Lakewood
For the record - this issue looks to have remedied itself.
LA_Sushi
Los Angeles
2022 Mach E Premium
My rear hatch close button hasn't worked since the day I got my MME (October 2022). Everything else seems to work for closing (the button below the license plate, key fob, touch screen) but the dedicate button seems completely dead. Any suggestions?
Ford Motor Company
Official Ford Account
Good morning! I can look into your concerns. Could you please send over a DM with your VIN and Ford dealer info?
BudC
Bud
St. Peters MO
2022 Mach-E Select RWD 2024 Kia EV9 GT-Line AWD
I just picked my car up from an auto body shop where I had a garage door scratch repainted (grrr!!!). Now, the hatch won't close via any electronic means (I get the 3 sets of 2 beeps, for a total of 6).
I guess there's no easy fix other than taking it in to the dealer? I imagine the warranty won't cover this since the body shop caused it (double grrrr!)
Neil4Real
I mean, are you really going to tell the dealer that is started after you got it back...? I would just take it in as normal and say it isn't opening via any electronic means and leave it at that.
BudC
Bud
St. Peters MO
I wonder if there would be codes in the computer that would tell them things were disassembled?
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Did you confirm that the body shop didn't disable it in settings?
BMT1071
Glendale, AZ
Or the system may have turned it off due to components being unplugged.
Shayne
Northern Ontario Canada
2021 MME4x Prem
I sometimes have to press the button a 2nd time to get it to close. That started after one of the updates (1.7.something) if I remember correctly.
But only that button on the far left is affected. If I press the center button then it works every time still.
The center button? The one on the tailgate that you press to get in? Never thought of trying that one to close it. ?
Mine has worked well sync, phone and buttons since I received it. I am trying to master kick open kick closed and getting pretty good at it. Has never been a problem and have been through the 1.7's.? I think you may not be in the norm.
BudC
Bud
St. Peters MO
None of the physical buttons, Sync buttons, fob, etc. will close it - only by manually pulling it down.
The power liftgate is activated in Settings (that's why it will open via the buttons).
Odd that it will open but not close...maybe a sensor is goofed up and that's why it refuses to come down??
BudC
Bud
St. Peters MO
So, I checked the diagnostic codes using my copy of FORSCAN and this guy came up:
Code: B1454 - Tailgate/Liftgate/Boot/Trunk Left Pinch Strip
I took it back to the body shop, showed them the code, and asked them to check all the electrical connections in the hatch. They found one that wasn't clicked all the way together, and ta-da, the hatch now works!
Another reason to know how to use FORSCAN ?
IMDIDOC
Alex
Buffalo NY
2021 Mach-E FE
Optometrist
Often mine will begin to close and then stop and beep. Push the button returns to full open, but when pushed to close repeats the beeping and stopping.
I have the First Edition so it has the foot activated close feature - or should I say it did, as it no longer works. Did they deactivate that feature in a software update?
My job 1 still has kick to open. I have (I think) the latest update. 4.2.something.
