Rear wiper blade - longer replacement?
21st Century Pony
Martin
Arlington, Virginia
Is that comparing it to the original or the 15?
It's pollen season here in Virginia. Walking by my car yesterday, I noticed the 16-inch Bosch A 401h wiper blade sweep line, both on the top and on the bottom by the wiper arm pivot point. IMHO this pic speaks for itself.
Ford Mustang Mach-E Rear wiper blade - longer replacement? 20230406_124332
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
Last Summer, thanks to Connoisseur's advice I bought and installed the Trico 15-G 15 inch rear blade.
However, last month thanks to Su-Ch+MachE's suggestion I ordered and installed the 16-inch Bosch A401H rear wiper blade.
Very happy with the result. The Bosch A401H blade sweep reaches a full 1/2 inch above the rear window's top defroster wire. And just like the Trico, the Bosch blade just clicks into the wiper arm.
Amazon says the A401H doesn't fit the Mach-E. Of course, I trust users in this forum over some algorithm any day ?. Ordering....
Teslaeata
Nottingham, England, UK
I changed the wiper arm & blade for a MkII Galaxy UK spec for larger swept area. Have just ordered your A401H to see if that’s any better.
21st Century Pony
Martin
Arlington, Virginia
was going to order but saw this warning?!? So
I suggest you try the 16-inch Bosch rear wiper blade. I had them both... the Bosch is better.
TJSparky
Travis
WA
2023 Mach-E GT Performance Edition
Just installed the Bosch A401H. Easy and functional mod for the rear window. ?
It’s going to tell you that, since this is not a direct-replacement part. Kind of like putting a 7 liter engine in where a 5 liter originally resided (or in my case a 7.5 where a 6.6 was). ??
shadowsjc
NJ
2021 Mach-E Premium AWD + Ext Range
I had previously installed a trico rear blade and it was difficult but I eventually got it on correctly. Today I tried to remove the trico and install the Bosch. But when I tried to pull off the trico, only the rubber blade assembly came off, but not the metal piece that "clicks" into place.
I think that metal piece is still attached to the right end of the wiper arm (I can see and feel a metal piece that I can easily pivot with my finger). I tried to yank it off but it was stuck pretty hard and I didn't want to break anything.
Should that small pivoting piece be there or do I need to yank it off with pliers before installing the Bosch?
Skyman63
Isabella, Mo
2024 Mach e GT, 2019 Ranger 4x4, 2017 C-Max Energi
Retired high school teacher
I was having a hard time finding the specific blades mentioned in this and similar threads in a store anywhere. My local O’Reilly’s Auto Parts had a Bosch Spectrum Direct Fit R1521 that works perfectly. Full contact with the glass along the whole blade, and goes right to the edge of the glass at the bottom. It has a little plastic locking cap that comes off easily, then it snaps tightly into place.
Ford Mustang Mach-E Rear wiper blade - longer replacement? 20240110_133154_Original
Ford Mustang Mach-E Rear wiper blade - longer replacement? 20240110_134901
ARK
Los Angeles
'21 Premium SR AWD
For those who have used Bosch replacement wipers, have they stayed on well? I decided to try a Bosch A351H, it is a 14 inch wiper. The wiper clicks in fine, but the Ford OEM wiper seems more stable because the connector is L shaped, whereas the Bosch just pops in and out.
Comparison pic of the connectors below - the Ford OEM is in the foreground while the Bosch A351H is in the background.
Ford Mustang Mach-E Rear wiper blade - longer replacement? IMG_1185
I haven’t tried using it yet, but it looks great on the vehicle. It doesn’t look too large, no overhang, doesn’t overshoot the edge. I know I won’t get as much coverage as a 15 or 16 inch wiper, but aesthetics were a priority for me, and I didn’t want any overhang or a wiper that wasn’t flush with the glass.
Below is a pic of the Bosch A351H installed, with the Ford OEM on top for comparison (I marked how far the OEM went on the right side to align it as it was when installed).
Ford Mustang Mach-E Rear wiper blade - longer replacement? IMG_1187
21st Century Pony
Martin
Arlington, Virginia
My 16-inch Bosch works great, even with occasional ice on the hatch
