Recommended Chargers
ohmslaw
Joseph
Connecticut
Toyota Highlander, Toyota Rav-4, Mach-e (on order)
Just ordered a Mach E last week..... in the 6 months of waiting I would like to install a charger (Would like to keep the mobile charger that comes with the car as that; mobile). Are there any chargers that people can recommend?
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
I have been using the mobile charger exclusively for almost 3 months now but it is starting to act flaky! Told my Wife that I was thinking about getting a Juice Box and she was like “ WTH are you talking about? “ lol
TheVirtualTim
Dearborn, MI
While any Level 2 EVSE with a J-1772 plug (which is basically everything on the market *except* Tesla) should work, ALWAYS check with your local electric utility because many of them offer some sort of rebate or incentive, but often limited to specific brands or models. For example, my utility offered a $500 rebate but only if I bought an approved ChargePoint or EnelX JuiceBox model.
That aside ... some of these things are hard-to-get (in short supply). ChargePoint shows up on Amazon and sells out within a day. People re-sell them for hundreds of dollars above list price (which is really about $700 ... but you'll see them being offered for $1000 or more).
I have both the ChargePoint Home Flex and the Ford Connected Charge Station.
If you're having problems getting something in stock then you might also consider the Ford Connected Charge Station (they are not hard to get ... you would be able to get one via your dealer).
ohmslaw
Joseph
Connecticut
Is the Ford Connected Charge Station available again? I know they pulled it off the market a bit.
Jeffvisor
Harrisburg, PA
Ford Mustang Mach-e
If you want a more expensive smart charger that is a plug in I would recommend the Wallbox Pulsar Plus. Advantage for plug in 14-50 chargers is you can move it with you if you ever relocated versus a hardwired. Advantage to Smart is you get additional data from the charger can use it scheduling and add in your electricity rate and can keep track of your cost. If you get another car in the future with less advanced options as the Mach-e this charger can do a lot of the things the Mach-e has built in to it. Wallbox is a small footprint, weather proof, extra long 25' cable well built and separate holster you can position closer to the car, you can set it to charge up to 40amps or less if preferred with 14-50 plug. Usually can purchase for $599 on Amazon or Wallbox website.
Motomax
Max
VW GLI, 4Runner
The Grizzl-e seem pretty popular for a relatively cheap no frills dumb charger that can do plug in or hard wire. That’s the one I got since it has a full aluminum housing and I’ll be leaving it outside. I didn’t see the need for the smart features, ideally it should be left up to the car to control charging schedules. Can’t comment on if it actually works though since my cars been waiting for a chip for two months.
TruWrecks
Grizzl-E Classic
Does the job very well and can be adjusted from 16V to 40 A for different circuit use.
I use this at 40 A and I can recharge my car from 0% to 100% in about 13 hours. It uses the 14-50 plug so if it ever fails I can still use the included 32 A charger until the Grizzl-E gets replaced.
Mine has been outside in the weather for almost 2 years.
KZ6e1e
LAX
P4X
Grizzl-E Classic
Refurbs directly from the Grizzl-E is a little bit cheaper and comes w/the same warranty btw. Also no tax and shipping (For US based buyers)
Jim D
Mahopac NY
Mustang Mach E - GT
Ditto here.
They seem to be out of stock on that link, and when I checked on Amazon the JuiceBox only had a hardwired 40AMP option there. As Amazon had the Checkpoint 14-50 40 AMP I went for it, delivery expected in a little over 2 weeks. My Ford Mobil charger died yesterday so my car was not charged this am so I took it up to the semi-local dc semi-fast (50KW) charger 18 miles away.
Tbird
Denny
New Hampshire
MachE GT 2025 (with Perf Upgrade), 2024 Kia EV6 GT-Line Trim
I just installed the chargepoint home flex. I have it hardwired with a 60 amp breaker and that prov ides 48 amps which is max amps for the mach E. It is wifi connected and provides reporting on charging status as well as a summary of previous charges at your home charger as well as public chargers.
I don't have the ChargePoint yet I get a record of all my public charges too, they are on the ChargePoint network...
