Jimbo
- Jimbo
- Dec 16, 2021
- US
- Premium 4X
You were not 'quoting' a document by Ford, you were reading a vaguely-worded Ford document and conjuring meaning from it.Sorry to say, but I was quoting the document by FORD and not some "genius/Nostradamus" on the internet with no firsthand knowledge. I was expressing a counterpoint to the opinions determined in a vacuum.
Ford's NHTSA notice says the remedy is to "monitor contactor temperature and intelligently reduce battery power to prevent damage to the contactor."
It doesn't say how conservative that temperature-based throttling is: is it incredibly conservative, such that most cars get throttled after five minutes of DCFC, or is it much more targeted?
It doesn't say how often it will apply: is the aforementioned damage they're trying to prevent cumulative (with relays and contactors, it often is), and this throttling will therefore occur quite regularly, or are these contactor failures single-incident damage, and the throttling will therefore be rarer? To both of these, Ford has provided no answer, and inferring anything else from the NHTSA notices is haruspicy.
Yet somehow you deduced "you could expect to see a power reduction less than .5% of the time"
Yes, I agree. It's also equally outrageous for Ford apologists to say "stop speculating! By the way, Ford is magically able to tell the precise moment a contactor will fail, and only then throttle power milliseconds before. This is totally not speculation, because Ford said they have 'intelligent monitoring'"And this is EXACTLY the operative point I was trying to make: deciding exactly what will happen with no actual first hand information, and then using that as a basis to foment internet rage is ridiculous.
