Goober96
Brent
SC
2021 Mach-E4X, 1996 Mustang Cobra, 2008 Corvette
Widget Tool updater worked great.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Sadly they don't have a web UI for all the access.
For the prior system (MyFordMobile) they had just about all the same commands from logging into the website as they did on the app. Thus it was super easy to open developer tools in Chrome and just watch the network tab...
This is why I need someone to use postman as a MiTM proxy to catch all the requests to Ford from the Fordpass App.
I would normally do this myself but I don’t have a Mach-E.
The only other way to get these quickly is if some trusting soul changes their ford password temporarily and shares their ford login with me :)
If anyone is trusting enough PM me please…
DosSpider
Mach E Premium RWD Ext Rng
Sent a PM, have a buddy that can probably help walk me through any roadblocks I'd run in to...will Fiddler work or does it have to be postman?
phidauex
Colorado
Renewable Energy Engineer
I have a test account authorized to my Fordpass - PM sent!
I'm looking for a few of you to test this out, please!
Ford Widget Tool Installer (tonesto7.github.io)
So the premise here is that I can't directly update a running script I need another script.
So I created the FordWidgetTool (It's based on scriptdudes installer).
You will go to the website which will hold your hand through installing the installer for the widget tool.
Once the tool is installed it automatically runs and it either installs the Fordpass Widget or updates the existing code.
It will walk you through the steps of installing a helper script that installs and updates the main widget script.
Once this tool is installed that's it, just tap it anytime I announce an upgrade and it just downloads it.
The only time I may require you to reinstall the tool is if there is a required update for the tool's new features. Either way, you will never have to copy and paste-like you did before.
I even recorded a couple of videos of the install process and set up for new users.
Worked flawlessly for me ?
can I offer a small HMI suggestion? I notice you are using check marks to indicate that the doors and windows are closed? Many people associate a checkmark with an indication that an activity has completed. Perhaps another icon might be clearer? Maybe a red/green Harvey ball?
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I’m not against that suggestion. I look at getting it into the next release
As long as you're taking cosmetic suggestions, what do you think about removing the word "Charger" and just having that field have the plug icon? On small phone screens (iPhone Mini), the title and status get truncated.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) 1640102615864
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Yeah sorry about that!
I don’t see that otherwise, I would have fixed it a week ago.
I like the idea of doing the for the batteries as well
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I also have the other charger api calls for the mache but I’m not sure exactly how to integrate them yet.
I thought maybe the charging account balance and charge time would be good on the widget
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Someone mentioned before removing the position from the medium size widget which I think I will do for you EV users
Ok, I’m probably about to become a PiTA here, so feel free to tell me to go away:
Is there any way for you to determine your window size, then choose the appropriate nomenclature/iconography? For example, if someone has a very small window, just use the plug icon. If they have a large window, use the text string?
