SAM
SAM
Central NJ
Premium MME4X Iconic Silver
Very nice enhancements. Worked flawlessly. After install, I had to manually delete the old FordPass script from Scriptable and the old widget from the iPhone home screen and then add the new widget to the home screen. I guess this was because I had not installed the FordWidgetTool previously.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Nicely formatted OTA now. ?
OTA Details
  • CorrelationID: FLARE-PRD-SOFTWARE-FNV2-405484-436308
  • Created: 2021-11-12T16:33:54.292+0000
  • Expiration: 2021-11-19T16:33:54.292+0000
  • Priority: HIGH
  • Type: NEW_FEATURE
  • Trigger: SOFTWARE
  • Inhibit Required: false
  • Environment: PRD
  • Latest Status:
    • Status: failure
    • Details: OTAM_E1016
    • DateTime: 2021-11-16T15:26:52.934+0000
  • Package Details:
    • WiFi Required: false
    • Priority: 1
    • FailedResponse: none
    • DisplayTime: No Data
    • ReleaseNotes:
      • FordPower-Up 1.7.1 Notes, Remote Vehicle Setup added; feature enhancements We’ve been busy. Notes lets you draw or take notes on your vehicle touchscreen. Your writings and artistic masterpieces can be saved. Notes includes a handy calculator and a tic-tac-toe board to kill time while waiting for that curbside takeout. Our new Remote Vehicle Setup lets you use FordPass™ or the owner’s site to set up profile preferences, including all your radio presets. It’s all stored in the cloud and sent to your Mustang Mach-E through the SYNC® 4A system. Navigation automatically makes helpful destination suggestions (but you can turn that off if you like), plus new cloud connectivity combines conversational voice command recognition with internet-based search, so you get the latest info with almost every request. Apple CarPlay® compatibility displays on-screen turn-by-turn navigation in your instrument cluster. Finally, the user-profile icons on your SiriusXM® with 360L radio will be a bit bigger, and there were a couple of bug fixes. Whew. Ongoing updates like these help ensure that you’re always driving the best possible version of your Mustang Mach-E. Keep in mind that update availability varies by model.
Thanks for reminding me of that!
Rebelchopper
Columbus GA
2010 F150, 2013 Santa Fe, 1968 Mustang, 2015 HD
Jet engine quality inspector
I got the script installed into Scriptable but Scriptable isn’t available as a Widget on my iPad or iPhone. I restarted but it still doesn’t show as addable. Any suggestions? Thanks.
Did you get it to work yet? I know this is a very late response, but you can open scriptable, run a script, and while the script is open go back and look for the scriptable widget. I had the same issue and that worked for me.
Goober96
Brent
SC
2021 Mach-E4X, 1996 Mustang Cobra, 2008 Corvette
Yeah it showed up like the next day or something. Just took some time.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Happy New Year Everyone!!!
I've been hard at work on v2.0 with the goal to basically eliminate the need to use the Fordpass App.
Data Request
The more data I have from everyone the more reliable I can make the widget.
Privacy Note:
This will be sent using your default email address which will be visible to me (I will never share or use the email)
If you have iCloud+ on iOS 15 (Settings > iCloud > Hide Email) you can create a random email and send using that email.
The following data will automatically be scrubbed and anonymized from the exported data, VIN, long & lat, address info.
Submitting Data:
  1. Install this version of the script over existing: Fordpass Widget.js
  2. Tap on the script in Scriptable
  3. Widget Settings
  4. Advanced Info
  5. Send Data to the developer.
This will generate an email and show the window with all the data attached as a JSON file.
Just select your email address and press Send
Coming Soon:
  • Tweaked widget layouts
  • Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) IMG_0434
  • Select different Remote Start Runtimes
  • New menu interface
  • Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) IMG_0432
  • Ability to view vehicle alerts & recalls, manage messages.
  • Hopefully, manage charge schedules for EV's
  • Voice control interface using Siri Shortcut
  • More items I haven't considered yet
Done, just sent it to you. Thank you Anthony for your continued development on this.
2026 Velocity Blue GT/CS
Thanks for all your hard work! I just sent off the email!
SAM
SAM
Central NJ
Done. Thanks again.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I made some tweaks to the script... Can those of you that submitted data please update the script using the link above and resubmit?
SAM
SAM
Central NJ
Updated and resubmitted. Thanks!
