ohmslaw
- Joseph
- Sep 18, 2021
- Connecticut
- Toyota Highlander, Toyota Rav-4, Mach-e (on order)
- Engineer
So I hate the fact that I have an electric car I could theoretically power by the sun and I am not doing that. I also a realist and know that the battery bank I would need to charge my daily use (Roughly 20kWh) would be really expensive and I would probably never recoup the cost of the batteries over the life of the vehicle.
I think I may have come up with a middle ground and a system that will be paid off after about 35k miles of Solar driving at my current electric rates.
The plan would be to disconnect our current Ford connected charge station and feed it through the inverter. The inverter I am looking at auto switches from battery power to grid power when batteries become depleted. Plug in every night and deplete the 5kWh batteries with the inverter switching to finish the charge. The charge station would be set to a max rate of 6A when plugged in during the day on weekends (to use as much Solar directly as possible to charge vehicle. while still trickle charging home batteries) and a higher value during the week to get to desired charge level daily.
The questions I have:
1.) Am I crazy? Is this worth the effort?
2.) How well does the onboard charger handle voltage transients?
3.) Any suggestions/tips for my proposed solution?
4.) Any other ways to approach this problem?
- Off-Grid configuration
- 5 kWh salvaged batteries. ($650 with BMS)
- Hybrid Inverter/Charger Split Phase 220 ($900)
- ~2kW of used solar panels ($1200)
- Misc hardware/wiring ($500)
