cafdiniz
Carlos
Irvine, CA
2021 MME Premium AWD ER
Disconnecting my phone has never helped. I’ve always had to reboot the phone, of which I reboot sync as well when I do it (not sure if sync reboot helps as much as the phone reboot though). I have the software installed as of today if it finished earlier today.
I’d love if it did help, but I’m guessing it is more for SXM that we don’t use.
I turn off the car, open/close the door, and then turn it on again. Not lying!
darkastor
Gerry
Minnesota
2021 Mach E Premium AWD extended
I saw on youtube someone turn on the WIFI to disconnect from Carplay and then shut it back off and reconnect the phone and it fixes it every time for me. I also pause whatever I'm listening to before I leave the car if I'm leaving it on and I have far fewer issues.
E90alex
Seattle, WA
‘25 MME GT
Hard to say, but funnily enough - their latest model, Capri, can manually precondition. Maybe Ford think of Mach E drivers like this:
Capri EV and Explorer EV have VW hardware underneath and likely running a reskinned version of VWs infotainment.
Mache_Nor
Norway
MachE LR RWD
But isn’t our Mach on similar platform as ID4? I could have sworn I’ve heard or read about it, but I’m not sure wether correct or not.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
I just received this OTA for my 21 job 2 car that is in EA.
thenew3
Central Coast CA
BMW X7, BMW X3, MME Premium 4X
Just received this in my 21 Job 1 in EA. First update since 07/2025. Went to move the car out of driveway after washing it and was greeted with the message that update installed successfully. Manually checked for updates an hour earlier (before starting to wash car) and it showed no updates.
ChuckUK
Chuck
UK
Mach-e AWD Extended range
The Electroverse App in the UK, which Ford moved adopted after closing blue oval, requires a PCID. Does the Mach-e have a PCID and if so how do you locate it?
My Ford account is linked to unlock my charging benefits. As far as I can see, there are no charging benefits, apart from plug n charge which is not available.
Ford Mustang Mach-E SYNC 26.2.1.6.5.2 OTA Update Installed IMG_1022
Ford Mustang Mach-E SYNC 26.2.1.6.5.2 OTA Update Installed IMG_1024
Ford Mustang Mach-E SYNC 26.2.1.6.5.2 OTA Update Installed IMG_1023
Got this today.
