This bothers me...
EVer
San Diego, CA
Ford F-150 SuperCrew Cab, Tesla Model 3P
erm, it didn't change it at all. It is unlikely they tested a Model Y with and without, and none of the EPA test procedures include cabin heat anyway.
EVer
San Diego, CA
Where did "the EV Media" get the range of a model Y without a heat pump? And given that cabin heat is never on during EPA test procedures, how could the method of cabin heat possibly make a difference?
Likely, the range score was adjusted around the same time as people learned it has a heat pump, and people imagined a cause and effect.
zhackwyatt
I wonder if that heat pump added any shade?
EVer
San Diego, CA
I can’t find any evidence Tesla announced the heat pump.
Tesla maintains battery temperatures using fluids, not with a heat pump. The heat pump is for the cabin. It makes no impact on EPA range. It was merely a coincidence that tesla released the manual including the high voltage components schematic (which revealed the heat pump) at roughly the same time the range rating was revised.
I’m not going to go digging for an article telling of the impossible. Might as well go look up a story of someone whose favorite sports team won after he did his ritual, and believed causation.
TheSteelRider
United States
'21 Premium RWD
Right on cue Jason from Engineering Explained.
TL;DR: He does confirm the heat pump is for cabin only
https://www.macheforum.com/site/threads/tesla-model-y-the-only-tesla-with-a-heat-pump.806/
Gilles
Gilles
Toronto, Canada
2021 Mach-e premium ER
I think we're talking different things here. I completely agree about L1/L2 charging. Meaning you're plugging in at home (or work) for 8+ hours while the car is parked, and you don't have to check on it or go move it after 30-40 minutes. Park it and forget it. That's perfect.
What we were discussing is L3 charging at retail stations, where you have to babysit the car by either sitting in it for 30-40 minutes every week or half-week, or finding something to do nearby (like eating at the same McDonalds 50 times/yr, or whatever happens to be next to the charging station).
If you look at TESLA, they have superchargers in shopping malls. One in Toronto is at the Fairview Mall and has 20 L3 chargers. They are intended for people that cannot charge at home. They can have lunch or do some shopping at the Mall (unfortunately not now due to COVID-19).
Another option, in NEO, China. They use battery swaps and have done over half a million swaps. One interesting option is to buy a car with a smaller battery (good enough for your normal use) and rent (for as little as $10/day) a larger battery when going on trips. On returning, you swap your battery back in your car.
Gilles
Gilles
Toronto, Canada
Why would it take time for the heat pump to work? It is an Air Conditioning in reverse. The main issue is that it does not work in very cold temperature (less than -5C or 20F).
dbsb3233
TimCO
Colorado, USA
I've thought about battery swaps before too, but I think the immense weight of that many batteries makes it impractical for passenger vehicles. That's not something people can do themselves. It would require heavy equipment and manpower, which is costly to install in many places. It would also require vehicles to be designed to easily slide or mount the battery packs in, with standardized packs. None of that exists or is likely to as manufacturers want to maximize the space and weight in the design of every model.
But I do wonder if it could be practical for certain commercial vehicles, like trucking? They usually go from a more standardized grid of truck stops. And it's a higher cost operation that might be able to justify the extra cost, especially it if keeps the vehicles running around the clock. Might be the only way to make EV trucking cost effective without having so much downtime from charging.
As for BEVs for people without home charging, there will be some that charge full time at retail stations, but I don't think that will be a big market share. It's just too time-consuming for most people. Home charging is perfect for BEVs. I think those that can't do it will just stick with ICE or PHEV.
Gilles
Gilles
Toronto, Canada
Look at NIO, they have 131 swapping stations in China. It takes 3 minutes to swap the battery.
This link has a nice video showing the automated swapping.
https://jalopnik.com/nio-has-completed-500-000-ev-battery-swaps-1843891655
timbop
That sounds like a REALLY small number for a country as big as china. I would guess that one of those stations would be much more expensive to build and run than a L3 DCFC charger, so is the idea really sustainable?
