worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
KadeBR
Devin
Western ND
2020 RR Explorer ST, 2021 RR GTPE
CDL Hazmat
Unless I missed it they actually claim 0-60 for gt now as 3.8 instead of 3.5.
Why did the GT 0-60 time change?
bbhaag
Maverick XLT, Mustang Mach-E GT Performance
They did it a couple of weeks back if I remember right. Now when you go to Fords page about the MME the specs for the GT now has a 3.8 0-60 time. The 0-60 time for the GTPE is now 3.5. Not sure what changed but something did.?‍♂
Ford Mustang Mach-E đź“„ 2023 Mach-E Models & Specs Comparison Spreadsheet image_2023-01-21_193148637
ARK
Los Angeles
'21 Premium SR AWD
It’s always been 3.5 for the GTPE and 3.8 for the GT.
Rob S
Robert
Long Island, NY
2017 Mustang Ecoboost, 2022 MME GT Star White
GTPE benefits from the stickier tires and 634 ft lbs torque vs 600 ft lbs for the GT (again, due to the tires). Motors are the same for both models.
KadeBR
Devin
Western ND
CDL Hazmat
Clearly says performance on the site is 3.8
Ford Mustang Mach-E đź“„ 2023 Mach-E Models & Specs Comparison Spreadsheet Screenshot_20230122-062341
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
Wait, so the 2023 Std range eAWD is slower than RWD? Also, I thought that the 2021 Select Std eAWD was supposed to get 5.2 0-60.
dj_stang
{None}
2022 MME Premium -> 2023 GTPE
Interesting, so laminated windshield glass (aka “SoundScreen”) isn’t available on GT or GTPE?
Will that make a noticeable difference in road noise?
Bayviews88
Kenya
SF Bay Area, California
2022 CA Rte1 RWD, Space White
The spreadsheet says that the CA Route 1 gets 312 miles with a standard battery, which is the same language used in the spreadsheet for the Select. The problem here is the CA Route 1 only comes with the extended 99 KWH battery.
worachj
worachj
Eagan, Mn USA
Thanks for pointing that out!
The spreadsheet is wrong because Ford's web page is wrong. The spreadsheet's data was just copied and pasted from the web page and not verified.
https://www.ford.com/suvs/mach-e/models/mach-e-california-route-1/
Ford Mustang Mach-E đź“„ 2023 Mach-E Models & Specs Comparison Spreadsheet Screen captur
worachj
worachj
Eagan, Mn USA
Just wanted to add, that I’m not maintaining the spreadsheet and keeping it up to date, so it will become out of sync with Ford’s website changes.
I put the spreadsheet together for help in making my decision on my order and posted it thinking it may be helpful to others.
ARK
Los Angeles
'21 Premium SR AWD
Making a GT a GTPE technically counts as adding a package, not it’s own trim, and so sometimes the website can’t cope well and gives you GT info even when you have the GTPE option selected. For example, that pic you posted also shows the GT wheels when the GTPE’s are definitely different.
Here is what the configurator looks like when you are made to choose between GT and GTPE, they have different 0-60 times.
Ford Mustang Mach-E đź“„ 2023 Mach-E Models & Specs Comparison Spreadsheet BB55F665-69EA-4116-A6C6-4A71FF5AB581
