- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
The difference between those two is whether or not the control pilot is switched off. Ideally the pilot should stay on and the car should say "Charging paused" the whole time it's plugged in. If it says "Plugged in not charging" the EVSE may no longer be operating in a J1772 compliant mode which could cause issues. So I would reach out to ChargePoint support about that as well.Regarding "Charging paused", it would usually say "Plugged in not charging". I changed that this morning to see if it could be the solution. Now instead of the *vehicle* having the charge schedule I set it to "charge whenever plugged in" and have the Chargepoint dictate when it charges on the schedule.
Perhaps that will stop the EVSE from pinging for charging data while it's plugged in since it has more inherent information about the session.
